04-06-2017, 14:14
#2 (permalink)
Member: 2082450
Thanks Meter: 1,454 | Quote:
Originally Posted by JayDi Code: Operation : Check / Read Info [ v1.59 ]
Wait for phone...
Phone found! [ 63 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6757
BB_CPU_NME : [MediaTek] Helio[P20]|MT6757_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM71C
[eMMC] : FLASH_CID : 150100574331374D4207CAABC8A4A367
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 64 GiB]
DEV RID : 0xB37B1BC7531F457252105171EF29E987
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
[AP] : Initial info read Ok!
Brand : UMI
ProdName : UMI_Plus_E
ProdModel : UMI Plus E
Device : UMI Plus E
AndroidVer: 6.0.1
MTKxCPU : MT6757
MTKxPRJ : alps-mp-m1.mp3-V1.20.3_even6757.66.m
EXTRA :
LCD : Not info available :(
LCD Res : 1920x1080
TOUCH [0] : GT1X
CAM [0] : s5k3l8_mipi_raw
CAM [1] : gc5005_mipi_raw
CAM [2] : imx219_mipi_raw
CAM [3] : imx230_mipi_raw
MODEM : agold_mt6757_lwctg_4m_common_g9
LOCALE : en_US zh_CN zh_TW
Done!
Elapsed: 00:00:08
Reconnect Power/Cable! Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.59 ]
Wait for phone...
Phone found! [ 63 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6757
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSNG Ok!
LSSNP Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:17
Reconnect Power/Cable! |
Hello brother,
Is v1.59 is coming for end users??
Is it true?? |
