09-18-2008, 10:02 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | can anybody share file for This set... According to User the Set got dead during Photo capture. When Checked with Infinity, The Set Seems to be with Blank Flash. Here are the pinouts --------------------------------------------- Initializing... done Cable: 2x5 (L10B) Power On ! software version: 1.14 cable type: 2x5 (L10B) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM13... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:3 Tx:8 time required: 14 sec Power On ! saved: Rocky_2008 ----------------------------------------------- Here Goes the operations log ------------------------------------------------ COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:6E03:0005 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support (mt62xx[at]mail.com) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size error: chip layout not detected error: chip layout not detected Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 84 sec Remove/Install battery now ! ----------------------------------------------------------- Please Check attchments for cfi_xxx.bin file. Do anybody have flash file for this set??? Thanks |
Can anybody reveal exports from this file??? | [Shadab_M] | GSM Programming & Reverse Engineering | 0 | 11-15-2009 16:41 |
can anybody share how can flash g700 set on setools | debmobile | SETool2 | 2 | 01-05-2009 06:19 |
can anybody share what parts this plese | debmobile | Samsung Hardware Repair | 3 | 12-11-2008 07:50 |
Can anybody share this file plese. | debmobile | Infinity-Box | 6 | 11-23-2008 21:07 |
can anybody share C35 flasher with me? | igor_m | x1x to x45/x50 | 0 | 09-07-2000 08:58 |
