Old 11-11-2008, 20:11   #1 (permalink)
Member: 275481
slt100 dead after flash
i have unlocked the phone, but it was asking for master code, i decided to flash it then unlock but after flashing the phone is dead, now i can not get it to connect it again, its not powering up again.
this is the log of flash
COM20 [VCP0] selected
module v2.40
Device: Fly-SLT100
Checking data, wait...
Action: write NAND flash
read mode: 01
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
source data: page only
identification#1 protocol ver: 04
ver. sw 1: SLT100_HMERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_3 6_MP_V36.BIN
ver. sw 2: MAUI.06A.W06.36.MP.V36, 00000000
ffs offset/size: 02000000/02000000
id-page1 Ok
nfi area detection finished: Ok
Boot ...
19200 fixed
Connecting, wait...
Initializing [6228:8A02:8A02]...
CPU: MT6228
chip: 0031:0000:0101
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.0207
loader: 3.748.0
NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb
NAND id: AD76AD76
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00AD:007600AD0076 [04200000]
NOR chip is not installed
Initialize Done
Set baud ...
115200
Set baud Done
Identification ...
reading structure area...
detecting structure...
id-page1 Ok
identification#1 structure: 2nd [standard] generation
Identification Done
Write ...
write core area 1 of 2...
write core area 2 of 2...
error: code: A500000BF3
error: code:
error: block/offset: 000011B0/011B0000
Old 11-11-2008, 21:58   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If phone can not be connected again you need to check battery voltage and charge battery with external power supply.
Old 11-12-2008, 12:53   #3 (permalink)
Member: 275481
Originally Posted by InfinitySupport View Post
Hello,
i have connected with usb power lead but still not connecting, i will try again with the battry charged
Old 11-12-2008, 18:09   #4 (permalink)
Member: 275481
Hello,
eaven with battery charged still no connection
pls help as customer can not wait
Old 11-12-2008, 18:39   #5 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
Look comfortable in using the 3.7vlts
Old 11-12-2008, 19:21   #6 (permalink)
Member: 130995
Hello,
If phone can not be connected you need to check battery voltage and charge battery with external power supply.
Old 11-12-2008, 21:37   #7 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
But I talked to him in a cell tests the source adjust, and put VLT 3.7 to test the unit ....
Old 11-12-2008, 23:39   #8 (permalink)
Member: 130995
Hello,
Yes. If phone hardware is Ok and battery is enough charged phone can boot in any case, even if flash chip is empty or wrong flashed.
Old 11-13-2008, 01:11   #9 (permalink)
Member: 728777
Thanks Meter: 11
i had this experience last time and buy a new phone to cusomer there definatly somthing wrong infinity support u must do a test on fly slt1oo thanx
Old 11-13-2008, 01:31   #10 (permalink)
Member: 130995
Hello,
It may be the next problem: damaged phone hardware or damaged cable.
There is no any other way why phone can not boot, so I suggest toy yo take your phone (that you have instead of other one), charge battery, double check cable and flash it again now.
6300 dead after flash 6233 dead after flash mobileZONE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-27-2010 01:17
Dead 9210e Orange UK Dead after flashing :( PhantomGSM Trisha & Matrix Flasher 4 05-06-2009 12:02
Page generated in 0.20701 seconds with 9 queries
