03-24-2009, 19:44 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: TUNISIA Age: 43
Member: 367280 Status: Offline Thanks Meter: 57 | can i unlock this phone thank you for help |
03-26-2009, 00:58 | #7 (permalink) |
Member: 367280 Status: Offline Thanks Meter: 57 | thank you for help thank you for help phone is done all work but no frensh language no need to press power on up 1 min ......is work with shortly press COM7 [VCP0] selected module v2.68 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2745:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090325-002500.B0X.bin Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16BJ20 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090325-004610.B0X.bin Finished, time used: 1295 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-26-2009, 01:10 | #8 (permalink) |
Member: 367280 Status: Offline Thanks Meter: 57 | for info for info when i try to load the full flash backup infinity give me this error Device: Alcatel-S320X Done Loading file v.02... error: data error ! Loading failed, probably damaged data file |
can i unlock this phone with cruiser SO506ic | nafg | Cruiser Suite | 5 | 10-05-2006 09:51 |
can hwk unlock this phone ?? | GIGOLO | HWK | 4 | 05-14-2006 09:24 |
e635 how can you unlock this phone? | junkiee24 | Samsung Flashers, Software, Firmware. | 0 | 01-27-2006 04:59 |
How Can I Unlock This Phone | sunrise gsm | VygisToolbox | 10 | 01-23-2006 15:31 |
i have v170 from tracfon can infinity unlock this phone? | gorgans | Infinity-Box | 9 | 10-14-2005 10:25 |
