Can Be Possible to Read pac file With CM2??? I Need Symphony V85 Firmware. Have any way to read Symphony V85 pac file With CM2?? (It's my first post.I hope Senior Member can help me) |
http://s32.postimg.org/r9yuoxkud/screenshot_4.png |
I think CM2 read in own format pac.sc.not PAC file for original flasher. |
Button for convert PAC.SC to SPD FACTORY PAC exists since "Read FW" was implemented. Need moment still not come. |
sir please will that button coming soon in our upcoming updates? |
in my opinion its not important that file is PAC.SC or PAC.when we read by CM2 then whats problem to write with CM2. |
We can't share file with friend who don't have CM2 . |
CM2 is not so expensive tool.everyone who is in GSM software field can buy easily this precious tool in reasonable price. |
I can't read symphony V85 pac with cm2... here is log... Card found: S/N : D09C9343 , v0130 Chinese Miracle II [SPD module] v 1.19 Operation : Read FullFlash [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 58 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:31 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 58 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:14 Reconnect Power/Cable! |
There are two options for SC7730..7731- Generic and A5, try with both options, with and without Alternative LDR Mode. Also try with sldr files manually. If nothing works need to select similar pac file. Br. Infinity Box Support Team. |
Where from I can find Sldr files??? plz sir ans me. |
ITS IN CM2SPD MODULE UNDER MODELS NAME. WBR sahil2000ind |
