10-21-2016, 06:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Cherry Mobile Omega HD Nitro SnapDragon 210 [MSM8909] Read Fw And Write Done Code: Operation : Read Flash [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 00A50FE3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : Cherry ProdName : H810 ProdModel : Omega HD Nitro Device : H810 AndroidVer: 5.1.1 Manufact. : Cherry QLMxCPU : MSM8909 QLMxPRJ : CHERRY_H810_V12_151008 DevInfo : MSM8909__Cherry__Cherry__ANDR_v5.1.1__Omega_HD_Nitro__H810__H810__CHERRY_H810_V12_151008 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : splash.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1054 MiB Done! Elapsed: 00:02:42 Code: Operation : Flash [ v1.00 ] Verify FW package ... Loading firware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Cherry Device Manufact.: Cherry Device Model : H810 Device CPU : MSM8909 Device IntName : H810 Device Version : 5.1.1 CU_SWVer : Cherry Device Compile : 10/8/2015 8:46:17 AM Device Project : CHERRY_H810_V12_151008 Device ExtInfo : Omega HD Nitro Load Ok! Operation : Flash [ v1.00 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 00A50FE3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Files in Chain : 25 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Flashing done! Done! Elapsed: 00:03:02 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to Rex For This Useful Post: |
