04-26-2018, 15:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | ZTE N9560 unsupported SecureType! Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : 85F58AEB ID_BLOCK_E : 00040000 ID_BLOCK_L : 22B43A996B81EA8FA0AF934F229C44C1 ID_BLOCK_L : 17DE023BC25DCFF4392FC390EE62F92F Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
04-26-2018, 16:37 | #3 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | Not working yet, here log: Code: Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : 85F58AEB ID_BLOCK_E : 00040000 ID_BLOCK_L : 22B43A996B81EA8FA0AF934F229C44C1 ID_BLOCK_L : 17DE023BC25DCFF4392FC390EE62F92F Use CM2 Internal Loader Loader Sent! Initializing ... ERROR : FH Configuration failed! HINT : Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
05-12-2018, 15:46 | #7 (permalink) | |
Member: 181633 Status: Offline Thanks Meter: 730 | Quote:
"adb reboot edl" ...without quotes Note: if you manage to enter fastboot also should work "fastboot reboot-edl"...I guess Last edited by jepetu; 05-12-2018 at 15:54. | |
