Canīt flash huawei G6150 COM1 [VCP0] selected module v4.27 Device: Huawei-G6150 Checking data, wait... Action: write flash write: Firmware Huawei-G6150_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.PTRC77B16 8SSC.BIN_FLNTY6701111184KC_En_Pt.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Huawei_G6150_ffs_01.B0E.bin nor area detection... interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: PTRC77B168SSC detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.PTRC77B168SSC.B IN_FLNTY6701111184KC project-id: PTRC77B168SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00D40000/002C0000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 2 loading files... number of areas: 2 done write... write core... error: can not write flash (0): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL Disconnect... done Finished, time used: 1 min 14 sec Remove/Install battery now ! What im doing wrong?! |
Hello, What is the problem with this phone ? Is it phone that can be power-on or is it completely dead phone ? |
