10-03-2022, 17:42 | #22 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Try with this version https://infinity-box.com/?r=100202 and post sw log text |
10-03-2022, 18:17 | #23 (permalink) | |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | Quote:
Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.36 Load IDBase v312457 Ok Server unavailable Username or Password is wrong - set it via Settings https://infinity-box.com/?r=100166 Load IDBase v312457 Ok Operation : Identify Device [ v2.36 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode : FLASH [+] SecureData Backup [+] AutoBoot [+] Read Deep Info: PRL, HW, DEBUG [+] FireFly : AutoEMI [+] FireFly : FireFly UNI-Proto [+] Smart Service Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : Reset Interface PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : 0x00007024 : DA SEND ERROR ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Retrieve device config... Try loaders: 1. 0_base/BASE_v2112/MTK_AllInOne_DA.bin Ok Error : Fail to init protocol >>> Remove battery and cable. Check cable/connection/drivers and repeat operation! Reconnect Power/Cable now | |
10-04-2022, 15:09 | #24 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | As per given log I can say that this HW was booted well with CM2MT2 earlier. Probably it was booted with Test Point or with Local SLA option checked. Try it. |
10-04-2022, 19:22 | #25 (permalink) |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | gui: Wide S/N: 5B933493 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.36 Load IDBase v312457 Ok Server unavailable Username or Password is wrong - set it via Settings https://infinity-box.com/?r=100166 Load IDBase v312457 Ok Operation : Change KG state [ v2.36 ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM9) MODE: PRELOADER PORT PORT: 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: SecLevel : 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : Reset Interface PTFN: MediaTek PreLoader USB VCOM (Android) (COM9) MODE: PRELOADER PORT PORT: 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: SecLevel : 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : 0x00007024 : DA SEND ERROR ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Retrieve device config... Try loaders: 1. 0_base/BASE_v2112/MTK_AllInOne_DA.bin Ok Error : Fail to init protocol >>> Remove battery and cable. Check cable/connection/drivers and repeat operation! Reconnect Power/Cable now Operation : Identify Device [ v2.36 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH [+] SecureData Backup [+] AutoBoot [+] Read Deep Info: PRL, HW, DEBUG [+] FireFly : AutoEMI [+] FireFly : FireFly UNI-Proto [+] Smart Service [-] Local SLA Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM9) MODE: PRELOADER PORT PORT: 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: SecLevel : 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : Reset Interface PTFN: MediaTek PreLoader USB VCOM (Android) (COM9) MODE: PRELOADER PORT PORT: 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: SecLevel : 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : 0x00007024 : DA SEND ERROR ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Retrieve device config... Try loaders: 1. 0_base/BASE_v2112/MTK_AllInOne_DA.bin Ok Error : Fail to init protocol >>> Remove battery and cable. Check cable/connection/drivers and repeat operation! Reconnect Power/Cable now gui: Wide log gui: Default gui: Wide Operation : Identify Device [ v2.36 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH [+] SecureData Backup [+] AutoBoot [+] Read Deep Info: PRL, HW, DEBUG [+] FireFly : AutoEMI [+] FireFly : FireFly UNI-Proto [+] Smart Service [+] Local SLA Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM9) MODE: PRELOADER PORT PORT: 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: SecLevel : 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : Reset Interface PTFN: MediaTek PreLoader USB VCOM (Android) (COM9) MODE: PRELOADER PORT PORT: 9 Waiting BOOT ack... PRELOADER : ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: SecLevel : 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : 0x00007024 : DA SEND ERROR ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Retrieve device config... Try loaders: 1. 0_base/BASE_v2112/MTK_AllInOne_DA.bin Ok Error : Fail to init protocol >>> Remove battery and cable. Check cable/connection/drivers and repeat operation! Reconnect Power/Cable now |
10-04-2022, 19:41 | #26 (permalink) |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | https://forum.gsmhosting.com/vbb/f29...nnect-3055868/ the same problem |
10-10-2022, 01:35 | #29 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Sorry for jumping into old thread. But sadly September patch closed the brom. Only preloader mode available. Techo is closing doors like vivo and oppo. Next is infinix. Going back to old time when oppo was being done remotely. Last edited by zishhaider; 10-10-2022 at 01:35. Reason: Spelling |
10-14-2022, 09:32 | #30 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,925 | we need sw log text for all models https://infinity-box.com/?r=100202 |
