10-31-2006, 07:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 18041 Status: Offline Thanks Meter: 2 | error in w220 this is log COM1 selected Device: W220 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 109A-000 HW ver: SCA-7- Check Flash Done Check Parameters... file saved: Backup_unlock_2006-10-30_23-9-53.6AF.bin Err: already prepared Check Parameters Fail Finished, time used: 21 sec Remove/Install battery now ! COM1 selected Phone must be POWERED-ON ! Connecting, wait... Err: connection failed, try again ! Finished COM1 selected Phone must be POWERED-ON ! Connecting, wait... Err: connection failed, try again ! Finished COM1 selected Phone must be POWERED-ON ! Connecting, wait... Phone connected. Working... Finished |
10-31-2006, 09:29 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Please, try to repeat unlock process, be sure that phone powered On and phone backlight is On during connection. Also, what version of Moto02 you used ? |
10-31-2006, 23:49 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, If you can find "unlock_log_...." file in Moto02 folder after unlock try, please, send it to me. If this file not exist, pls, send me "operation.log" file: [email protected] |
11-08-2006, 14:14 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, don't be so lazy to spend 1 minute in "search" and "FAQ" thread reading: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 http://forum.gsmhosting.com/vbb/showthread.php?t=346877 |
11-29-2006, 22:38 | #7 (permalink) |
Freak Poster Join Date: Feb 2005 Location: on earth
Member: 120740 Status: Offline Thanks Meter: 3 | i had same problem i try and try with diffrent 7 phone all the time connction failed . when i did prepare is ok for unlock so i used with 9v batt reset settings when reset setting done do read sp unlock codes it work perfectly |
12-01-2006, 10:52 | #8 (permalink) | |
Junior Member Join Date: Dec 2004
Member: 99366 Status: Offline Thanks Meter: 0 | Quote:
i have the same problem | |
12-01-2006, 11:16 | #10 (permalink) | |
phone unlock. thanks. I have used 9v. Last edited by raulo; 12-01-2006 at 11:29. Reason: explain the solution. | |
charging problem in w220 motorolla | max98372 | Motorola Hardware Repair | 4 | 02-20-2009 08:10 |
W220 No Power error in FFS | ASHRIFF | Infinity-Box | 3 | 05-12-2008 19:21 |
specific imsi puk in w220 | ras | Infinity-Box | 7 | 10-06-2007 07:51 |
help in w220 phone is on when come to me but now dead after i repair imei | saily | Infinity-Box | 5 | 09-03-2007 10:02 |
diffrent problem in W220 | rk19801 | Motorola Hardware Repair | 2 | 08-10-2007 11:02 |
