Old 12-12-2016, 11:43   #1 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
Hi guys hope you can help me with my y511-u30
before i flash the device the phone stocks at logo then i flash it with errors and the phone now is dead i get the firmware in this link
http://consumer.huawei.com/bd/suppor...d.htm?id=24803
and the logs is quoted below
Scatter Load Ok , BaseBand : MT6572 , Project : wt98511 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 43 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048604A2170B41EF
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048604A2170B41EF
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xD05B159F2934007164CEA9582CADF950
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : wt98511 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3788 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:16
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt98511.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:47
Reconnect Power/Cable!
i already erase flash couple of times both on sp flash tools and on my cm2
br: dyo
Old 12-12-2016, 12:01   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. eMMC is gone to "ReadOnly" state. Need change.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-12-2016, 15:45   #3 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
need to change the chip?
The Following User Says Thank You to dyo For This Useful Post:
Old 12-12-2016, 16:52   #4 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
offcourse, becouse it is hynix. Only at samsung EMMC can remove WriteProtection.
Page generated in 0.14872 seconds with 9 queries
