02-23-2009, 11:19 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: The land of rape and honey Age: 46
Member: 40118 Status: Offline Thanks Meter: 97 | Can't do anything with Fly B700 COM16 [VCP1] selected module v2.65 Action: read codes unlock method: read codes Model: Fly-B700 CPU1 (main) Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6205:8B00]... CPU: MT6205 error: initialize step #1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 27 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [19.02.2009 18:08:06] ==== COM16 [VCP1] selected module v2.65 Device: Fly-B700 CPU1 (main) Checking data, wait... advanced flash detection enabled Action: "format ffs" enhanced security fix enabled Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: CKT_NEPC06A_PCB01_GSM_MT6205B_DN.SWAN_6205_GY_210_ 071206_SP53.BIN ver. sw 2: SWAN_6205_GY_210_071206_SP53, 00000000 ffs offset/size: 00300000/00100000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E221A2201:18E59F00000000 error: wrong erase first sector at 0x00E00000 Finalization Fail Finished, time used: 21 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
02-23-2009, 17:59 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hi, This phone has 2 CPU. To remove user code you need to connect to 1st CPU (6226) but not to 2nd CPU. You need to use other Rx/Tx and connect to 1st CPU. |
I really can't do anything with this software!!!! | kaino147 | Motorola P2K (USB-Smart) | 16 | 03-09-2006 03:25 |
JAF BOX - can't do anything to my 3650 | shahzad9 | WD2 & APE (Symbian Phones) | 1 | 10-30-2005 21:35 |
Can't do anything with Nokia 3200 | UnReality | Twisterflasher | 6 | 07-11-2005 00:55 |
activate GTI fail I can't do anything now | segsm | Griffin | 10 | 06-06-2005 00:20 |
