11-26-2008, 17:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Cant foud konka EC003 in MModule I just installed MModule v;2.47 but cant found this phone model. regards. |
11-26-2008, 18:52 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I remember Beetel-EC003 model was supported. Please, check, is Beetel-EC003 is the same model as Konka-EC003. To be sure in success make this: run ChineseMiracle, read full flash from Konka-EC003 like "MT6205-MT6227" model and send full flash backup to [email protected] We will check file and will give you an advice. Also pls post here Konka-EC003 pinout. |
11-26-2008, 20:53 | #3 (permalink) | |
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Quote:
log details, Pinout and full flash backup link below: http://www.4shared.com/file/73271507...nka_ce003.html | |
11-26-2008, 21:57 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thanks for files, we have got it. Our programmers will check files carefully and hope we can release update in 1 day so please, try to keep phone with you for 1 more day. |
11-27-2008, 17:31 | #5 (permalink) | |
Tell me about pinout if good; regards | |
11-27-2008, 18:29 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to unlock phone with this software: http://www.infinity-box.com/download/public/MModule.rar Waiting for your results |
11-27-2008, 20:17 | #7 (permalink) |
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | PHONE SUCCESSFULLY UNLOCKED; C LOG DETAIL: COM4 [VCP0] selected module v2.48 Device: Konka-EC003 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN ver. sw 2: KABEC003FM_EN_FR_ES_4.01.918, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... ......... lock area found Patch required data Done Special operation ... detecting additional parameters... ..... flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/1 ........... additional parameters detected Ok Special operation Done Write ... flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 31 sec Remove/Install battery now ! |
The Following User Says Thank You to .:==di@bila==:. For This Useful Post: |
[ERROR] Alcatel s319a not imei repair in MMODULE v2.78 | WeBoXGT | Infinity-Box | 2 | 06-28-2009 08:25 |
Sucessfully Unlock Konka EC003 | umadineshdas | Infinity-Box | 5 | 03-09-2009 06:59 |
Help Unlock Konka EC003 | nishue | Infinity-Box | 2 | 12-21-2008 11:02 |
29 Nov 2008: Alcatel-S319, S320, Konka-EC003 models supported | InfinitySupport | Infinity-Box | 36 | 12-12-2008 21:40 |
29 Nov 2008: Alcatel-S319, S320, Konka-EC003 models supported | zinoubinabil | Service Products News & Updates | 0 | 11-29-2008 07:56 |
