Old 12-01-2010, 15:33   #1 (permalink)
Member: 1231161
Thanks Meter: 7
Infinity does not read or write flash in the N97 and N97 Chinese
Please infinity team how to solve this??
COM15 [VCP0] selected
Módulo v3.25
Dispositivo: Autodetect 6205-6239 NOR
Verificando Dados. Aguarde...
Detecção Avançada da Flash Habilitada
Action: read flash
====> Boot ...
Pressione e SEGURE o Botão de Ligar!
19200 fixed
Conectando. Aguarde...
Inicializando [6235:8A04:8A01]...
CPU: MT6235
Boot Em Alta Velocidade On
chip: 0000:0000:0003
status: FF
Tamanho do Pacote de Inicialização: 0400
Solte o Botão de Ligar!
Em Caso de Problemas Com a Conexão Inicial: Ligue/Desligue "Seleção Autom. da Vel. de Inicialização"
Boot Fail
Finalizado. Tempo Gasto: 12 sec
Remova/Recoloque a Bateria!
The Following User Says Thank You to marcel09 For This Useful Post:
Old 12-01-2010, 21:25   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must select "NAND" type on settings page
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 12-02-2010, 13:04   #3 (permalink)
Member: 1231161
Thanks Meter: 7
thanksssss solvedddddd
Old 12-02-2010, 16:39   #4 (permalink)
Member: 1231161
Thanks Meter: 7
after flash the phone so do not start flashing
Módulo v3.25
Dispositivo: Autodetect 6228-6253 NAND
Action: write flash NAND
Escrever Firmware
E708_PXHT1_PCB01_GPRS_MT6235B_S01.01_0__N97_128Mb_ En_Fr_Es_Pt_It_De_Ml_Id_Cz_Slovak_Nl_Tr_Vn_Ru_Bg_P ersian_Cn.B4M.bin
Pular: Customization/Language Pack
Pular: Eeprom/ffs
nfi area detection...
external bootloader is not present
bootloader version: E708_BOOTLOADER_V005_MT6235B_01_1.bin
nfi area detection (3 cores) finished: Ok
"Formatar FFS" Ativado
interface: BROM_DLL_v3.1016.00
Connectar...
O Telefone Deverá Estar DESLIGADO!
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0058]: 002C:00A100800015 [MICRON] MT29F1G08ABB
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
Feito
Set baudrate (460800)...
Feito
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
Tamanho/Offset do FFS: 03000000/05000000
firmware size: 48Mb
ffs size: 80Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: E708_JJF1NCOMP.01.0
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 05
sw version: E708_JJF1NCOMP_PCB01_GPRS_MT6235B_S01.01_0.BIN
project-id: E708_JJF1NCOMP.01.0, 00000000
code offset: 00000000
ffs offset/size [01]: 03000000/05000000
rom info structure: [standard] type (05)
TCL-ID is absent
===> Feito
New firmware found (v.3.25, database date: 23.11.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Ler FullFlash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
startup code area #1 check...
Feito
number of cores: 3
loading files...
number of areas: 3
Feito
write...
write bootloader...
write core...
Aviso: can not format: HW_STORAGE_NOR is not present
Format (HW_STORAGE_NOR)...
Disconnect...
Feito
Finalizado. Tempo Gasto: 26 min 34 sec
Old 12-02-2010, 21:08   #5 (permalink)
Member: 148515
hello!
your phone's original software version is E708_JJF1NCOMP_PCB01_GPRS_MT6235B_S01.01_0
why did you flash it with different file?
did you make full backup before this operation?
Old 12-03-2010, 13:04   #6 (permalink)
Member: 1231161
Thanks Meter: 7
hello!
I did not phone this up but it happens in two equal and the other phones I did backup most stays the same ....
Old 12-03-2010, 21:41   #7 (permalink)
Member: 148515
hello!
now you must find this file "E708_JJF1NCOMP_PCB01_GPRS_MT6235B_S01.01_0"
with other it will not get repaired
Old 12-07-2010, 13:11   #8 (permalink)
Member: 1231161
Thanks Meter: 7
please where can I find this version of the firmware has no support .... please help
Old 12-07-2010, 14:40   #9 (permalink)
Member: 1231161
Thanks Meter: 7
hello!
I found this firmware but not in this format to infinity can not you convert to infinity ...
MEGAUPLOAD - The leading online storage and file delivery service
thanksss
Old 12-07-2010, 18:26   #10 (permalink)
Member: 1251379
Thanks Meter: 2
Same problem here, I can´t find another Chiang Jiang N97 to make full backup and restore one phone I have.
I use the STAR N97 image (E708_PXHT1_PCB01_GPRS_MT6235B_S01.01_0_B4M.bin). Everything works BUT touchscreen. Have acces to full functions by qwerty keyboard.
The file you link is for Flash Tools and I never be able to restore the phone with that file (no boot).
Old 12-07-2010, 18:56   #11 (permalink)
Member: 1251379
Thanks Meter: 2
Update
Now I remember, I try the same image from suport (E708_PXHT1_PCB01_GPRS_MT6235B_S01) and have same fail result.
Try this file
Is a STAR N97 Infinity Box image I have and works with CJ N97. Remember, touch screen not work, everything else OK.
The Following User Says Thank You to mx-t2 For This Useful Post:
Old 07-27-2011, 00:03   #12 (permalink)
Member: 179402
Thanks Meter: 21
Try this file
File not found, can you upload again please
Old 09-24-2012, 08:08   #13 (permalink)
ganjbek's Avatar
Member: 1246378
Thanks Meter: 123
Old 09-24-2012, 17:16   #14 (permalink)
Member: 179402
Thanks Meter: 21
N97_E708_JJF1NCOMP.01.rar
Old 09-25-2012, 18:40   #15 (permalink)
Member: 1630737
Thanks Meter: 27
I have this problem friends
COM3 [VCP0] selected
module v3.26
Action: reset settings ("format ffs")
Model: Autodetect 6228-6253 NAND
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:5603:0009
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button more long time !
error: operation failed !
Finished, time used: 1 min 25 sec
Remove/Install battery now !
help
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.23248 seconds with 9 queries
