Old 11-04-2009, 22:57   #1 (permalink)
Member: 364992
Thanks Meter: 28
5 k200 corrupted with infinity
hi.. i have flashed 5 different sony k200.. with main, ffs and eprom... after flash i unlocked it.. and... not charge.. says always usupported accessory..
i flash with setool and problem persist..
problem start when i flash phone with infinity because i have checked and works ok and charge ok before flash... i want to flash because not save pics...
Old 11-05-2009, 00:58   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If you think that phones was damaged by Infinity-Box you can try to flash phone with Setool.
But if even after flashing with two different tools you have the same result...
What do you think, where is the problem ?
Old 11-05-2009, 01:06   #3 (permalink)
Member: 364992
Thanks Meter: 28
Originally Posted by InfinitySupport View Post
Hello,
You not understand me....
i received k200 with the problem no save pics...
i check if phone charge.. and charge OK:..
then i flash phone with infinity with main, ffs and eprom.. and unlock it...
then.. i check the phone and not charge and when i connect charger says: unsupported accessory...
then i try to flash with setool and problem persist....
is obviously that the problem is with infinity box...
and now i have 5 k200 with the same error.. all flashed with infinity..
it will be better if you help me to solve this problem instead of fight with this conversation....
thanks..
Old 11-05-2009, 01:12   #4 (permalink)
Member: 130995
Hello,
If you have flashed phones with Setool and problem persist this means that it's a problem that was caused not by Infinity-Box.
Why so ?
Because if f.e. Infinity-Box makes a problem for your phone - the problem should be repaired with Setool.
But if problem still exist with Setool, you can say that "Problem caused by Setool" but not "Problem caused by Infinity-Box".
Please, confirm, did you understand my idea ?
Also, if you have selected a way to ask for help like "Infinity-Box damaged phone and even Setool can not repair my phones" - it's a wrong way to ask help.
Yes, I have some ideas how it was happened that YOU have damaged your phones, but I need to get a HONEST confirmation from you, that your phones was damaged by YOU but not by Infinity-Box and not by Setool.
p.s.
please, post here text from this Infinity-Box manual: C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Repair_SE-K200i_SE-K220i_Camera-not-save.txt
Old 11-05-2009, 01:17   #5 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
i already faced this problem,i confirm not problem by infinity box!!!!
why???=because it was problem caused by wrong files choosing and the procedure,after change firmwares(files) and check the right options phone work well and problem charge is ok
regards,
The Following 2 Users Say Thank You to toutou_gsm For This Useful Post:
Old 11-05-2009, 01:32   #6 (permalink)
Member: 364992
Thanks Meter: 28
regards,
Ok.. but i check phone before flash with infinity and phone charge...
maybe becouse.. i select to flash, MAIN, FFS and EPROM and with setool y only flash MAIN and FFS.. not eprom.. maybe eprom problem...
totou... what selection are u talking about...???
Old 11-05-2009, 01:33   #7 (permalink)
Member: 130995
Hello,
What is the reason of your total ignorance of my advices and questions ?
Please, explain.
Thank you !
Old 11-05-2009, 01:36   #8 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
please re-write new main and ffs,after finish test the charge problem,if was ok,if no!! flash only eeprom file(dont flash main, ffs and eeprom in one time) ,i think u will fix the problem (its not a big one)
try and post result
regards,
The Following User Says Thank You to toutou_gsm For This Useful Post:
Old 11-05-2009, 20:24   #9 (permalink)
Member: 364992
Thanks Meter: 28
Hello,
Please, explain.
Thank you !
what is the part of my explanation do you not understand..
I have 5 k200a phones from different customer all with software problem..
i flash all the phones with infinity, all works ok but no charge.. "unssupported accesory".. i checked 2 phones before flash with any tool and charge OK!!!!!!
After flash with infinity have "unssupported accesory", i backup eprom from NEW phone.. and write to charge problem phone.. and still the same error..
i flash like ttoutous way and still the error..
i read repair camera.txt and do that and still the error...
and.. YES i break this 5 phones but with infinity box.. not with other tool...
man i need your help i not want to fight... thats all!
give me instructions and i will post logs..
Old 11-05-2009, 20:44   #10 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
FLASH ONLY THIS EEPROM FILE K200i_repair_ffs_01_master-reset.80E.bin
ENABLE FORMAT FFS IN TABLE SETTING
TRY AND POST RESULT
MAKE SUR ALSO IF UR PHONES K200A OR K200I BECAUSE ITS DIFFERENT
Old 11-05-2009, 22:06   #11 (permalink)
Member: 364992
Thanks Meter: 28
tested same error...
Old 11-05-2009, 23:17   #12 (permalink)
Member: 364992
Thanks Meter: 28
can found a solution please...
Old 11-06-2009, 17:05   #13 (permalink)
Member: 364992
Thanks Meter: 28
Please infinity support help with this problem.. i see a lot of people in this forum with same problem..
is 1000% software problem.. tested..
Old 11-07-2009, 02:00   #14 (permalink)
Member: 130995
@Indyss
I have asked some questions but I did not got any answers yet.
Please, check my posts again.
http://forum.gsmhosting.com/vbb/show...74&postcount=4
http://forum.gsmhosting.com/vbb/show...05&postcount=7
Old 11-10-2009, 21:26   #15 (permalink)
Member: 364992
Thanks Meter: 28
i not understand you questions.... but i can tell you .. i have 5 k200 with software bugs.. not save pics, etc..
first i flash it with infinity i problem solved but get error when charge.. accesory not supported., then i flash with setool to repair that problem and nothing... problem persist..
i tried with other phone.. first i check and charge ok.. then i flash with infinity and not charge.. "accesory not supported" then i flash it with setool and still the same error...
that was my procedure...
i need your help to solve this.. i flash like says this txt
and still the problem.
here the text:
Infinity-Box How to repair SE-K200i SE-K220i "Camera not save"
1. Run software
2. Go to "Flash" page
3. Uncheck "Firmware" box
4. Uncheck "Flex" box
5. Check "Eeprom" box
6. Load repair eeprom file: K200i_repair_ffs_07.80E.bin or K200i_repair_ffs_0A.80E.bin
7. Uncheck "Format FFS" box
8. Press "Write" button
9. Follow instructions in software log window
10. if phone become locked and can't accept sim-card make "Unlock" procedure
i do that.. and still not charge..
chinese cocktail 9.5 file corrupt neville Chinese Cocktail 6 12-03-2010 23:28
lg k200 format with help of pinfinder joni_rajpura Infinity-Box 2 12-31-2008 17:42
.:::::kg275 blinks after flash with infinity help infinity support ::::::. SAMEER TAHIR Infinity-Box 1 09-16-2008 20:58
Help me infinity team step by step flash lg kg195 with infinity aamirgsm Infinity-Box 1 08-07-2008 14:28
i try flyslt100 unlocking with infinity but phone dead plz help infinity team qaziomer Infinity-Box 4 03-30-2008 19:43
Page generated in 0.25835 seconds with 9 queries
