Old 12-09-2005, 18:49   #1 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
Question Can't write flash in C115!
Motorola is working and i try to write russian files in it, but i got this error message:
Write: Firmware
Write: Flex
Write: Language Pack
Device: C115/C116
Checking data, wait...
Connect...
Press and Hold Power button...
Err: B03: 66746D746F6F6C
Connect Fail
Finished
Remove/Install battery now !
Time used: 6 sec
or this tipe:
Write: Firmware
Write: Flex
Device: C115/C116
Connect...
Release Power button !
Connect Done
Boot...
Err: [04]
Boot Fail
Finished
Time used: 12 sec
The phone is not damaged, it's working OK, but i tryed 3 pieces to write and got the same error. What can i do in this cases???!!!
P.S. : C155 flashing is working OK!
Old 12-09-2005, 19:34   #2 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
Just try to re-configuration USB-TO-COM latency timer or use normal Com cable.
B/r
Old 12-09-2005, 20:22   #3 (permalink)
Member: 130995
Thanks Meter: 35,228
Hi,
Check "Documentation" folder and you will see how to make changes in COM port settings.
Old 12-09-2005, 20:31   #4 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
i configured the port, because C155 does not worked and after configurateing C155 is working fine, but C155 - NOT!
Old 12-13-2005, 11:15   #5 (permalink)
ringo's Avatar
Member: 3180
Thanks Meter: 12
same problem, ..so i use normal serial ( not USB) interface and all it's OK..try it.
b.r.
Old 12-13-2005, 22:55   #6 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
I tryed so many (using USB or COM) times and ... nothing!
Old 12-14-2005, 00:40   #7 (permalink)
Member: 130995
Hello,
It's for sure cable problem. If it not works with ordinary COM port cable it's very strange but in any case I am sure it's cable problem.
Old 12-14-2005, 15:18   #8 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
Try This ..............
Old 12-14-2005, 15:51   #9 (permalink)
ringo's Avatar
Member: 3180
Thanks Meter: 12
btw , what SO u have? cos under XP i got all that error messages u receive but under win98 with normal serial interface all it's OK. I supose on XP some comunication protocols r more secure, try with win98.
b.r.
p.s.also i open phone to be sure that conector it's plug in complete
Old 12-15-2005, 22:10   #10 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
Thank to all of you! Yes, I work on XP! I will try tomorrow using Win 98 and i will write the results!
Old 12-16-2005, 15:47   #11 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
i hawe same problem. on XP and on 98 too.
tested on 3 uniboxes
will made new cable
Old 12-17-2005, 13:16   #12 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
tested on 4 phones new cables xp and win98 but nothing same problem
Old 12-17-2005, 13:27   #13 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
Is This Phones Whit New Boot ? How CAN I Chek It?
Old 12-17-2005, 17:35   #14 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
The same problem. It doesn't work in Win98. C155 is working, but C115 - not. This is not a cable problem, because C155 is working 100%!!! How you can explain this?
Old 12-19-2005, 12:14   #15 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
Angry
ffffffffffffffffffffffffff
can't write flash in 3220 using UFS3 dj_mseal UFS2 + UFS3-Tornadoflasher 2 02-27-2014 05:25
C115 can't write flash! ionelka Infinity-Box 1 12-03-2005 17:24
Can't write GDFS in AVR format to T610 & T630 doctormike Cruiser Suite 11 07-28-2005 22:59
Can't erase and write flash in C30! Tygiel x1x to x45/x50 0 08-18-2002 15:51
Page generated in 0.18204 seconds with 10 queries
