CECT i70 COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:A07D:A765 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: FFFFFFFFFFFFFF:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... detecting firmware version... .................................................. .............. .................................................. .............. .................................................. .............. can't detect firmware version if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting languages... .................................................. .............. error: can't detect language parameter #1 can't detect language names if software not respond/freez: make "Find language names (slow process)" unchecked and repeat operation. Check firmware content Done Backup required data... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080923-171235.B0E.bin flash: FFFFFFFFFFFFFF:FFFFFF00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: FFFFFFFFFFFFFF:FFFFFF00000000 error: no any expected answer error: flash erase error: 00E00000 error: no any expected answer error: erase #E2 Finalization Fail Finished, time used: 348 sec Remove/Install battery now ! |
hello! this is a log of formating phone with damaged flash IC |
