08-20-2007, 16:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: NIGERIA, DELTA STATE, WARRI
Member: 53891 Status: Offline Thanks Meter: 41 | Cect v200 (N22 Nokia) Format Problem COM55 [Serial2] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification detection finished device-id: 27EADFDB protocol ver: 04 ver. sw1: MY6226_PCB01_GPRS_MT6226_S01.DM200_V009_1_5_MATRIX _GKW.BIN ver. sw2: DM200.V009.1.5.MATRIX.GKW ffs offset/size: 00F00000/00100000 detecting eeprom area in 1 chip(s)... flash: 89880F00010001:89880F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? operation terminated by user error: critical error#1 during eeprom size detection error: can't detect eeprom address/size error: no any expected answer Finished, time used: 51 sec Remove/Install battery now ! At the front of it is written N22 NOKIA and at the back its written CECT V200. Pls help. |
08-20-2007, 21:45 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Dear Sir, As I can see from log software ask your answer and you terminated operation. In this situation no data was cahnged/erased/written in phone so phone can't be damaged. You must charge battery, make full flash backup and repeat operation. |
08-21-2007, 21:35 | #6 (permalink) |
Member: 53891 Status: Offline Thanks Meter: 41 | Here's the result when i tried formatting: COM10 [Serial2] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification detection finished device-id: 27EADFDB protocol ver: 04 ver. sw1: MY6226_PCB01_GPRS_MT6226_S01.DM200_V009_1_5_MATRIX _GKW.BIN ver. sw2: DM200.V009.1.5.MATRIX.GKW ffs offset/size: 00F00000/00100000 detecting eeprom area in 1 chip(s)... flash: 89880F00010001:89880F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF reading [eeprom[MY6226_PCB01_GPRS_MT6226_S01.DM200_V009_1_5_MATRIX _GKW.BIN]]... file saved: backup_eeprom[MY6226_PCB01_GPRS_MT6226_S01.DM200_V009_1_5_MATRIX _GKW.BIN]_20070821-212914.B0E.bin flash: 89880F00010001:89880F00000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 89880F00010001:89880F00000000 Write Done Finished, time used: 253 sec Remove/Install battery now ! And here's result when i tried reading backup: COM10 [Serial2] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification detection finished device-id: 27EADFDB protocol ver: 04 ver. sw1: MY6226_PCB01_GPRS_MT6226_S01.DM200_V009_1_5_MATRIX _GKW.BIN ver. sw2: DM200.V009.1.5.MATRIX.GKW ffs offset/size: 00F00000/00100000 detecting eeprom area in 1 chip(s)... flash: 89880F00010001:89880F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF error: no any expected answer Finished, time used: 54 sec Remove/Install battery now ! Right now, phone no longer coming on. It was initially going off when simcard is inserted. pls whats the next step? Can i get flash in support? |
FLS-5 Nokia Flash Prommer (Original from Nokia) without problem any Nokia Flashing.. | GSMFLASCH | Main Sales Section | 0 | 10-28-2008 17:51 |
Plese help for cect q380 flashing. And format prosidure. | debmobile | SpiderMan | 13 | 09-22-2008 16:46 |
How to Unlock Drxian CECT v200 phone from Hong kong | mangorobin | Chinese Models & Cloned Phones | 3 | 07-22-2008 09:48 |
Guide ME for Cect t689 flash & format ok but cant power on | 22229999 | Infinity-Box | 5 | 02-18-2008 20:31 |
