11-26-2015, 11:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Cherry Mobile Flare S3 Lite Unknown Structure Detected i have here flare s3 lite brandnew error on read back up firmware Operation : Check/Read Info [ v1.06 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 583 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_W15.26_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 06-23-2015 14:29:29 Phone Security Info : IMEI [1] : 351949072733838 IMEI [2] : 351949072733846 BT_ADDR : 000000000000 Done Reconnect Power/Cable! Operation : Read FullFlash [ v1.06 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 583 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.06 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 584 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:15 Reconnect Power/Cable! |
11-27-2015, 03:57 | #3 (permalink) |
Member: 3468 Status: Offline Thanks Meter: 308 | Hi, not work on new update v.1.07, select cpu (SC773x Android 5x) Operation : Check/Read Info [ v1.07 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 584 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
