01-14-2009, 14:10 | #1 (permalink) |
Major Poster Join Date: Mar 2007
Member: 471808 Status: Offline Thanks Meter: 5 | china set dead COM17 [VCP0] selected module v2.74 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A503:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98004900000002:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090114-182437.B0E.bin flash: 98004900000002:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:FFFFFF00000000 Finalization Done Finished, time used: 252 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! error: wrong file size[0x00000200]: C:\Program Files\InfinityBox\ChineseMiracle\cfi_0098_0049_000 0_0002.bin |
01-17-2009, 17:51 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is a log of format FFS on phone with totally erased flash chip open operation.log and find First operation which you did with this phone. check its original firmware version and find proper flash file on our support area |
Help infinity team china set dead after full format? | malikawan | Infinity-Box | 3 | 10-02-2009 10:38 |
china set dead by format with infinity | eswar7983 | Infinity-Box | 6 | 06-03-2009 23:01 |
N95 8gb china phone dead set pls help | topnoyze | PadFinder box | 1 | 08-12-2008 07:52 |
after format my china set full dead | unlock & flash | Chinese Models & Cloned Phones | 13 | 05-25-2008 14:16 |
plz help dead china set | asad_nomy7 | Infinity-Box | 7 | 03-28-2008 11:50 |
