11-13-2008, 04:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: cabanatuan city(philippines)
Member: 247229 Status: Offline Thanks Meter: 19 | sagem my226 unlock done with pinfinder logs: COM23 [VCP0] selected Device: Sagem-my226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH 280607_1821 EBI_IH_280607_1821 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-sta_20081112-203323.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-sec_20081112-203340.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-complete_20081112-203347.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 246 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 happy unlocking |
The Following 2 Users Say Thank You to psyrooze For This Useful Post: |
11-13-2008, 16:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
9530 verizon blackberry unlocking done with mx | rajesh_ch | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 11:57 |
SAGEM MyX 150 unlock done with infinity | sajidashraf | Infinity-Box | 2 | 03-18-2009 13:11 |
