china n8 i have a china n8 set which was having the problem of sim card registration failed .. i tried to read the full flash and then change the IMEI but i am not able to read the flash but in the ON mode i can change the imei .. any of the pinfinder does not work in this set except gpg dragon . then i try to find the RX TX on the board and soldered the wires directly but i am not able read , or format this set ... Code: Action: read/check information http://forum.gsmhosting.com/vbb/f646...olved-1232303/ how can i read the full flash of this set and then format and change the imei ? |
hello! so, can you find pinout using GPG dragon? |
yes i can find the pinout by dragon .. but now i have connected the set soldering RX TX in the PCB .. how to connect ? |
what should i do to repair this set ? |
Select "Autodetect 6228-6268 Nand" option and try again. Wr. |
done the set only with the latest module v3.29 chinese miracle version .. now i am checking the set if it is working ok for some time .. thanks infinity team .. Code: ==== [4/8/2011 12:12:58 PM] ==== |
If phone is working fine send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage Wr. |
Would you upload somewhere your backup ? I want that firmware ... Thanks in advance |
Help me flie N8 mtk 6235 ..... Help me file : SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005.BIN Thanks so much :o |
must be very rare or new firmware. unfortunately we dont have it in our collection. you can try to search for same working phone on local market. read out full backup and use it for flashing your faulty phone. also i can convert to infinity format BIN file, if you find it. by the way, did you try to solve your problem without flashing, just by format FFS/IMEI restoring? |
