01-11-2010, 13:40 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Pakistan
Member: 243167 Status: Offline Thanks Meter: 14 | China Nokia 5330 Firmware required its firmware name is not present so i send picture of this phone kindly see it and give me file As Soon As Possible. http://rapidshare.com/files/33363486..._5330.rar.html |
01-11-2010, 17:08 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we can advice you a flash file after you post here log of "Read detailed information" also, let us know what problem do you have with your phone and have you tried to solve it by format FFS? |
01-12-2010, 19:17 | #3 (permalink) |
Member: 243167 Status: Offline Thanks Meter: 14 | Sir, it cannot ok after format ffs coz it alredy erase whole chip no firmware or epprom in this phone and i send it log file iff you required log here: ==== log opened: [1/11/2010 4:26:04 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v3.05 S/N: 35F6:0112 Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/11/2010 4:26:19 PM] ==== COM3 [VCP0] selected module v3.05 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:B203:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01027E02200200:18859F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01027E02200200:18859F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01027E02200200:18859F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01027E02200200:18859F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01027E02200200:18859F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01027E02200200:18859F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18909F8518909F8518909F8518909F8518909F8518909F85 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 01027E02200200:18859F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100111-163326.B0E.bin flash: 01027E02200200:18859F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01027E02200200:18859F00000000 Finalization Done Finished, time used: 7 min 27 sec Remove/Install battery now ! and i send you it currept eprom read file as a link file kindly download and see it Link here: http://rapidshare.com/files/33427053...6.B0E.rar.html Thanks |
01-13-2010, 19:04 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must open with notepad operation.log file which is located in Chinese Miracle folder. scrool it from up from end and find First operation with this phone. there you will see Original software version. post it here |
01-14-2010, 11:29 | #7 (permalink) |
Member: 243167 Status: Offline Thanks Meter: 14 | Yes sir, it is first opration file who i send you already i have recevied this phone in same condition who i send you last post so kindly give me this file and i send you pictures of this phone kindly see it. i send you link kindly download it...... link Here: http://rapidshare.com/files/33363486..._5330.rar.html |
nokia 5800 firmware unlock this model | simlock | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 04-09-2010 11:22 |
want nokia 5330 china pinout | .::Dr.Gsm::. | Infinity-Box | 11 | 10-31-2009 08:04 |
Nokia N80 firmware V3.0617.0.6 (UK) required. | Ron1 | Nokia Base Band 5 ( BB-5 ) | 8 | 06-09-2006 01:22 |
NOKIA 6310i UPGRADE FIRMWARE REQUIRED | doditnt | Nokia Digital Core Technology 4 ( DCT-4 ) | 14 | 03-01-2005 21:25 |
