china NOKLA n96 slider please infinty support i have N96 slider like NOKIA N96 orginal but it is china when i made *#0000# nokia n96 v 05.20 12-11-07 RM-233 nokia variant 00.00 i make info by infinity box using nokia usb cable CA-129 and i get this Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: HX696_GEMINI_07B_HW Software version: JL696_FA10_NS5_V1.9C Software date: 2006.06.14 Barcode: 121501MT012345678901234845 10 imei-1: 355287200029050 Finished, time used: 4 sec Remove/Install battery now ! and i search in support area and find this three file HX696_GEMINI_07B_HW[1].JL696_AR8_NS5_V1_9CTEST--090611_16m_En_Fr_Es_It_Tr_Farsi_Pt_Ar.B0M HX696_GEMINI_07B_HW[1].JL696_AR8_NS5_V1_9CTEST--090819__N96-RH-84_16m_En_Tr_Farsi_Ar.B0M HX696_GEMINI_07B_HW[1].JL696_SM6_NS5_V1_9CTEST--090930__NOKIA-N96_16m_En_Ml_Id_Th_Vn_Cn.B0M now i want to change language to arabic how can i do and which cable can i used to read fullflex and reflex this model pleasssssssssssssssse |
hello! you must assemble com port cable, but first we must make sure which pinout has this phone. do you have multimeter? |
yes i have multimeter |
hello! best way to find pinout if you dont have Pinfinder is to measure voltages on powered On phone. 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx after this is done you can proceed to cable assembling. here is good step-by-step tutorial: http://forum.gsmhosting.com/vbb/f296...-cable-386780/ |
