04-23-2010, 18:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Panamá
Member: 86124 Status: Offline Sonork: 100.1604943 Thanks Meter: 111 | LG GB190a unlock error module v3.36 Action: "sp-unlock" unlock method: smart fast Model: LG-GB190a Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B756:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2005.07.11 Version: 1.0 Version: GB190aOL-01-V10a-TFO-XXX-SEP-25-2009 Version: ARIMA6223_07A_HW 45 byte(s) read imei: 01201700012150 connection Ok 158 byte(s) read reading data... reading data #2... building new data... writing data... 146 byte(s) read reading data... 976 byte(s) read building new data... error: data is invalid Finished, time used: 15 sec Remove/Install battery now ! full flash link: GigaSize.com: Host and Share your Files |
04-23-2010, 20:17 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | COM14 [VCP0] selected module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 012017001644269 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8816:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: A7213_07A_PCB01_GPRS_MT6223_S00.GB190AOL-01-V10A-732-101-OCT-02-2009.BIN project-id: GB190aOL-01-V10a-732-101-OCT-02-2009, 00000000 code offset: 00000000 ffs offset/size [01]: 01400000/00C00000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01400000 standard ffs/eeprom offset confirmed: 01400000 detecting ffs/eeprom size... ffs/eeprom size: 00C00000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01400000-01FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 89890100040089:89890100000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ..................... detect standard ffs/eeprom location pass #1... .................................................. .............................. detect extended ffs/eeprom location pass #1... .................................................. ................... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 13579024681122 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 89890100040089:89890100000000 flash: 89890100040089:89890100000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 89890100040089:89890100000000 Finalization Done Finished, time used: 2 min 33 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-23-2010, 20:56 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @Nacam try to use this latest software, it has support for new GB190 firmware types: http://www.infinity-box.com/download...e_v3.37_v4.rar Waiting for your results. |
04-23-2010, 21:14 | #5 (permalink) | |
Member: 86124 Status: Offline Sonork: 100.1604943 Thanks Meter: 111 | Quote:
module v3.37 Action: "sp-unlock" unlock method: smart fast Model: LG-GB190a Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:94A2:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2005.07.11 Version: 1.0 Version: GB190aOL-01-V10a-TFO-XXX-SEP-25-2009 Version: ARIMA6223_07A_HW 45 byte(s) read imei: 01201700011854 connection Ok 158 byte(s) read reading data... building new data... writing data... 146 byte(s) read reading data... 976 byte(s) read building new data... error: data is invalid Finished, time used: 12 sec Remove/Install battery now ! | |
The Following User Says Thank You to GuilleC_PMA For This Useful Post: |
04-23-2010, 21:32 | #7 (permalink) |
Member: 86124 Status: Offline Sonork: 100.1604943 Thanks Meter: 111 | Thanks YellowBoss This method is succesfull: COM5 [VCP0] selected module v3.37 Device: LG-GB190a Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:94A2:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.37, database date: 23.04.2010): A7213_07A_PCB01_GPRS_MT6223_S00.GB190AOL-01-V10A-TFO-XXX-SEP-25-2009.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: A7213_07A_PCB01_GPRS_MT6223_S00.GB190AOL-01-V10A-TFO-XXX-SEP-25-2009.BIN project-id: GB190aOL-01-V10a-TFO-XXX-SEP-25-2009, 00000000 code offset: 00000000 ffs offset/size [01]: 01400000/00C00000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01400000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 89890100040089:89890100000000 Backup required data Done ====> Patch required data ... .................................................. ................... lock area found .................................................. ................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .................................................. ............................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ........................... required data found flash: 89890100040089:89890100000000 flash: 89890100040089:89890100000000 Write: area 2 (pass 1) .................................................. .................................................. . area 2 patch applied Ok Special operation Done ====> Write ... flash: 89890100040089:89890100000000 flash: 89890100040089:89890100000000 Write: lock-area-1 flash: 89890100040089:89890100000000 flash: 89890100040089:89890100000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 4 min 43 sec Remove/Install battery now ! |
04-23-2010, 22:04 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, If you still have phone on hands, please, try to unlock it with "smart fast" method once again with this new software (I hope this test helps us to find what was the problem). http://www.infinity-box.com/download...e_v3.37_v5.rar |
04-23-2010, 22:55 | #9 (permalink) |
Member: 86124 Status: Offline Sonork: 100.1604943 Thanks Meter: 111 | Same error appear unlock method: smart fast Model: LG-GB190a Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9925:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2005.07.11 Version: 1.0 Version: GB190aOL-01-V10a-TFO-XXX-SEP-25-2009 Version: ARIMA6223_07A_HW 45 byte(s) read imei: 01201700014081 connection Ok 158 byte(s) read reading data... reading data #2... building new data... writing data... 146 byte(s) read reading data... 976 byte(s) read building new data... unknown lock type error: data is invalid Finished, time used: 27 sec Remove/Install battery now ! |
06-02-2010, 05:05 | #10 (permalink) |
Freak Poster Join Date: Oct 2006 Location: United States
Member: 376302 Status: Offline Thanks Meter: 30 | GB190a Claro Dominican Republic Not Unlock COM3 [VCP0] selected module v3.39 Device: LG-GB190a Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B416:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.39, database date: 28.05.2010): A7213_07A_PCB01_GPRS_MT6223_S00.GB190AOL-01-V10A-370-02-JAN-04-2010.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: A7213_07A_PCB01_GPRS_MT6223_S00.GB190AOL-01-V10A-370-02-JAN-04-2010.BIN project-id: GB190aOL-01-V10a-370-02-JAN-04-2010, 00000000 code offset: 00000000 ffs offset/size [01]: 01400000/00C00000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01400000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 89890100040089:89890100000000 Backup required data Done ====> Patch required data ... .................................................. ................. lock area found .................................................. ................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .................................................. ............................ error: area 1 can not apply patch detecting parameters to apply patch area 2... .................................................. .................................................. ............................ error: area 2 can not apply patch Special operation Done ====> Write ... flash: 89890100040089:89890100000000 flash: 89890100040089:89890100000000 Write: lock-area-1 flash: 89890100040089:89890100000000 flash: 89890100040089:89890100000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 32 sec Remove/Install battery now ! |
06-02-2010, 05:07 | #11 (permalink) |
Member: 376302 Status: Offline Thanks Meter: 30 | Smart Fast Fail Unlock COM3 [VCP0] selected module v3.39 Action: "sp-unlock" unlock method: smart fast Model: LG-GB190a Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B416:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2005.07.11 Version: 1.0 Version: GB190aOL-01-V10a-370-02-JAN-04-2010 Version: ARIMA6223_07A_HW 45 byte(s) read imei: 01201700117805 connection Ok 158 byte(s) read reading data... building new data... writing data... 146 byte(s) read reading data... 976 byte(s) read building new data... warning: unknown lock mode: 00000000 error: data is invalid Finished, time used: 12 sec Remove/Install battery now ! |
06-02-2010, 10:29 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We want to buy this phone for research, we will pay for phone and delivery. If you can sell this phone to us, please, contact to [email protected] or ICQ 561878718 and talk about delivery. Thank you ! |
07-22-2010, 15:56 | #13 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Land of Lakes and Volcanoes Age: 51
Member: 111014 Status: Offline Thanks Meter: 132 | The only way to unlock this phone is doing a format smart-fast, then u enter unlock code 8 zeros, but problem is imei became corrupts, and can't be repaired, any idea? |
The Following User Says Thank You to nicacel For This Useful Post: |
07-26-2010, 21:37 | #15 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 39
Member: 138583 Status: Offline Thanks Meter: 120 | u can in mode 2: Code: COM15 [VCP0] selected module v3.52 Action: "repair imei" imei write method: mode-2 new imei: 012017000096453 Model: LG-GB190a Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B62A:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2005.07.11 Version: 1.0 Version: GB190aOL-01-V10a-TFO-XXX-SEP-25-2009 Version: ARIMA6223_07A_HW 45 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 45 byte(s) read verification... verification done: 01201700009645 Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to -luigi- For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
