BENCHENA | 02-28-2010 01:48 | chinese fone with ILLEGAL Software ! hello
i have received a chinese fone power off with sim .
i formatted it complete and after get SOFTWARE ILLEGAL .
this is log Quote:
COM4 [VCP0] selected
module v3.07
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:A43C:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.06279CA1.[GINWAVE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.XDWY-PASSAT_02_V1_2_012_090114.BIN_60B8E17F].rpl
rom info detection finished
device-id: 06279CA1
rom info ver: 04
sw version: GINWAVE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.XDWY-PASSAT_02_V1_2_012_090114.BIN
project-id: XDWY-PASSAT_02_V1_2_012_090114, 7FE1B860
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: GINWAVE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.XDWY-PASSAT_02_V1_2_012_090114__ffs...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\GINWAVE23C_08A_GE MINI_PCB01_GPRS_MT6223P_S00.XDWY-PASSAT_02_V1_2_012_090114__ffs_20100226-200511.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.XDWY-PASSAT_02_V1_2_012_090114__system_log_06279CA1_60B 8E17F_20100226-200542.B0X.bin
Finished, time used: 2 min 50 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
| have tried repair bad software but nothing changed !
what i should do ? |
