09-29-2014, 18:39 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/MediaTek v1.01 - MT6261 CPU supported .MediaTek MT6261 CPU supported Supported Operations: Read Info / Check Write Flash Read Flash Format FS Repair Security .MT625A, MT6260 support improved Support latest FlashLoaders Improved Format FS procedure .Other FlashID database updated FlashLoaders updated Some bugfixes - Official download link: server1 download area Test report: http://forum.gsmhosting.com/vbb/f296...d-1st-1863353/ If you can not run Chinese-Miracle-2 software: - Please read instruction: http://forum.gsmhosting.com/vbb/f296...ocess-1865047/ Test reports: - Please post test reports (operation log text) in current thread or here http://forum.gsmhosting.com/vbb/f296...iatek-1862422/ Infinity-Box 9 (nine) years (2005 - 2014) non-stop regular updates and support, as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - Infinity-Box Variants & Packages - Follow us on Twitter Last edited by InfinityHelp; 06-27-2020 at 09:57. Reason: legacy links removed |
The Following 6 Users Say Thank You to YellowBoss For This Useful Post: |
10-08-2014, 08:09 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: India
Member: 949240 Status: Offline Thanks Meter: 86 | celkon a95 pro error in format Operation : Format FileSystem [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Processing DA stage DA Stat : v3.2 on BBID : 0x84 NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 [NAND] : FLASH_LEN : 0x20000000 NAND not supported yet INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Boot Error! Elapsed: 00:00:04 Reconnect Power/Cable! |
10-09-2014, 12:36 | #9 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | unable to read codes Infinity team Today i tried to read codes on micromax x337 but unable. Here is log Code: Wait for phone... Phone found! [ 76 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 18C485D4D4DFD0219253CCBE80DA168D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Backup done Read ExtData Sorting ExtData Seems as code not set Break operation Done! Elapsed: 00:00:20 Reconnect Power/Cable! Same tried on miracle done in seconds Code: Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.92 Update:14-09-01 Firmware Version:1.12 Connected OK. Please check the network. Fuzzy Logic Method is very safe and reliable ! Waiting for USB Port... Set MTK USB Port (COM76) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6260 Ver: CB00 SW:0000 Test Mode, Reading Information From the Phone... UnLock Code: 1414 |
10-09-2014, 16:46 | #10 (permalink) | ||
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Check here : http://forum.gsmhosting.com/vbb/f296...-352e-1866558/ Quote:
Probably, in some of next version, will add reading also , so, will be read and reset as well. | ||
10-10-2014, 06:56 | #11 (permalink) | ||
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Micromax x282 flashing error at the same time flash with other tool success Quote:
Note :- I'm check every thing like cable change, port change, reinsert battery ,ect ... Same set imei write success Quote:
The Following 2 Users Say Thank You to .::AZEEM::. For This Useful Post: |
