03-02-2015, 16:49 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Chinese Miracle-2 MTK/MediaTek v1.14 - MTK Nokia 215 Support MTK Nokia 215 Support - Activated Nokia 215 support Supported Revision: RM-1110, RM-1111, RM-1112 Supported Operations: Read Info, Format FS Other: Flash ID database updated Factory FW read improved FlashUpdate packaged updated Note: Nokia MTK phones require Nokia Serial driver (download it from Support Area) Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service Last edited by YellowBoss; 06-25-2020 at 21:11. |
The Following 11 Users Say Thank You to InfinitySupport For This Useful Post: |
03-02-2015, 19:35 | #4 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | iBall Slide 7236 3G17 Read Factory Firmware/NVRAM/Pattern Lock Done By Infinity CM2 Operation : Check / Read Info [ v1.14 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642032591D84634193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E436172642032591D84634193 [eMMC] : FLASH_LEN : 0x00000000E7400000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : iBall ProdName : iBall Slide 7236 3G17 ProdModel : 7236 3G17 Device : iBall AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.TABLET.MP.V1 Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read Flash [ v1.14 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642032591D84634193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E436172642032591D84634193 [eMMC] : FLASH_LEN : 0x00000000E7400000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : iBall ProdName : iBall Slide 7236 3G17 ProdModel : 7236 3G17 Device : iBall AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.TABLET.MP.V1 [Read Ok] : preloader_iball82_6126.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / iball82_6126 / EMMC FW Size : 838 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__iBall__7236 3G17__iBall__4.2.2__ALPS.JB5.TABLET.MP.V1\ All done! Done! Elapsed: 00:04:21 Reconnect Power/Cable! Operation : Read NVRAM [ v1.14 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642032591D84634193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E436172642032591D84634193 [eMMC] : FLASH_LEN : 0x00000000E7400000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, MT6582_eMMC.spnv saved Done! Elapsed: 00:01:22 Reconnect Power/Cable! Operation : Read PatternLock [ v1.14 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642032591D84634193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E436172642032591D84634193 [eMMC] : FLASH_LEN : 0x00000000E7400000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1023 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 1475963 Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
03-02-2015, 19:37 | #5 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | team u allready add it into best tool than why need to add it big box - MTKx Flash Engine revised Nokia 215 ( RM-1110 , RM-1111 , RM-1112 ) supported Its. Maybe. Bonus who. Not have best dongle - Activated Nokia 215 support what. Meaning of. Active. Nokia |
03-02-2015, 19:57 | #6 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
1. Just to shout up possible " first in world support chinese box bla-bla-bla " and e.t.c. 2. Just to be, as other Nokia MTK phone. CM2 support all current Nokia MTK Phones. Yes, bonus. Activated - mean it added to list of supported. BEST can service MTK Nokia with much aspects , can flash and unlock, repair. CM2 can make read info/check and reset/format phone. Some peoples need it only. Who want service them more better - can activate BEST after. | |
03-02-2015, 20:12 | #7 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .:iTRi:.
Member: 240068 Status: Offline Thanks Meter: 201 | nokia 108 error connecting Wait for phone... Phone found! [ 62 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : A927091BEED80AA42B3053EA89B17C49 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0x00) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Boot Error! |
03-02-2015, 20:49 | #8 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn Titanium S6 Scatter Flashing Done By Infinity CM2. Operation : Check / Read Info [ v1.14 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201955DC4BE417D DA Stat : v4.2 on BBID : 0x87 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Code: Scatter Load Ok , BaseBand : MT6582 , Project : jxd_t8000l_w , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.14 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201955DC4BE417D DA Stat : v4.2 on BBID : 0x87 Configure emi settings DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201955DC4BE417D [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : jxd_t8000l_w , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Switching to HSUSB HSUSB Init Ok SecCfg Passed , 1799 BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BMT remark not need. Will skip Sending Preloader ... Use : preloader_jxd_t8000l_w.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Processing : Flash Pre-Erase Erase : MBR Erase : EBR1 Erase : SECCFG Erase : UBOOT Erase : BOOTIMG Erase : RECOVERY Erase : SEC_RO Erase : MISC Erase : LOGO Erase : EBR2 Erase : EXPDB Erase : ANDROID Erase : CACHE Erase : USRDATA Erase : FAT Flash Pre-Erase Done, time used : 00:01:04 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:01:42 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:01:13 Done! Elapsed: 00:04:18 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
03-02-2015, 20:54 | #9 (permalink) | |
03-03-2015, 00:47 | #10 (permalink) |
No Life Poster Join Date: Oct 2007 Location: PT
Member: 600502 Status: Offline Sonork: 100.1653742 Thanks Meter: 91 | hi can give some of this updates to Content Extractor users we pay but no updates for a long time give a bonus please thanks |
03-03-2015, 05:57 | #11 (permalink) | |
03-03-2015, 08:48 | #12 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | I'm testing scatter writing Chinese Miracle II [MTK module] v 1.14 Scatter Load Ok , BaseBand : MT6572 , Project : m1_allview_ro , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.14 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 91 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447583F10E8FF910B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447583F10E8FF910B [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : m1_allview_ro , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Switching to HSUSB HSUSB Init Ok SecCfg Passed , 1799 BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BMT remark not need. Will skip Sending Preloader ... Use : preloader_m1_allview_ro.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Processing : Flash Pre-Erase Erase : MBR Erase : EBR1 Erase : SECCFG Erase : UBOOT Erase : BOOTIMG Erase : RECOVERY Erase : SEC_RO Erase : MISC Erase : LOGO Erase : EXPDB Erase : ANDROID Erase : CACHE Erase : USRDATA Erase : FAT Erase Error! Something went wrong! Done! Elapsed: 00:01:41 Reconnect Power/Cable! |
03-03-2015, 09:16 | #13 (permalink) | |
