10-25-2015, 14:15 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Chinese Miracle-2 MTK/Mediatek v1.35 - Nokia 222, New MTK Android and MTK FP features MTK SP/FP Platform - Flash Engine updated Improved HW compatibility check Other changes and improvements - Service operations improved - NVRAM operations on SP platform revised Some bugfixes and changes, some old nvram files will not work anymore - BB Detection improved - Compile Info detection improved - Security Repair Improved - "FormatFS" revised for MTK Android New mode supported: Full Factory + FS repair Option make FullFactory Reset and also repair ExtData Very useful for "slow" phones, which run after format up to 5-10 minutes and stuck on BootLogo - UserData operations improved Android: "Reset UserLocks" operation improved for some models Android: PhoneBook Reading improved (big DBStorage is supported now) - Privacy Lock reset improved MT6580/MT6735/MT6753: PrivacyLock reset supported - WorldFirst! >Normal Reset >UserData Safe reset In both cases by default data will be safe - Smart AV engine updated - Engine completely revised - DeepScan improved - Detection revised - Revised Verification - "One virus left" problem fixed Strongly recomend to use latest version to avoid "hang" problem on some phones! - Firmware reading improved eMMC: Brand-specific improvements eMMC/NAND: Verification improved Supported Platforms for Factory FW Reading: MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6753/MT6795/MT87xx/MT83xx with eMMC MT625A/MT6260/MT6261 with SF/NOR MT6571/MT6572 with NAND - Other FlashID database updated FlashLoaders updated Some bugfixes and improvements FP MTKx Nokia - New secured FlashUpdate package supported - New Nokia MTKx models supported: Nokia 222 SS/DS: RM-1136, RM-1137 Now CM2 support ALL existing Nokia MTK phones Supported operations: Identify, FormatFS - New Nokia MTKx Feature - Repair FS during Format - WorldFirst! Special for Nokia 220 "browser" problem after "FormatFS" Just use "FormatFS" without any kind of additional settings selection Official download link Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else - Infinity-Box - News Unlock Codes (Huawei, SE, Motorola, Samsung etc.), iPhone Unlock, Software Activations - Infinity-Box Online Service - Infinity-Box Dongle ready for delivery - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Telegram |
The Following 47 Users Say Thank You to InfinitySupport For This Useful Post: |
10-25-2015, 18:23 | #5 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | sir did you fix two device works at one time ,,,,,as most awaited solution still need to fix ,,,,,, as i got cm2 activation on BOX,,,wherease i got dongl also ,,,but cant use BOX until dongle open and down once ,,,,and you severaly time promised to solve this in coming updates,,,, When will it fix sir ? |
10-25-2015, 18:28 | #6 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
10-25-2015, 19:07 | #9 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Best team ever... Anything from this team called infinity is for real no fake and hidden charges made.. Kuddddoooooooos to infinity team. I love you guyz |
The Following User Says Thank You to johnoroo37 For This Useful Post: |
10-25-2015, 19:32 | #10 (permalink) |
Freak Poster Join Date: Feb 2005 Location: egypt
Member: 119435 Status: Offline Thanks Meter: 52 | g7106 copy Operation : Remove Viruses [SmartAV] [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930101DC7622A7101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 110100303034473930101DC7622A7101 [eMMC] : FLASH_EXT : 00200000/00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 356 AVVerify : Too much data! Break! Send report to support Error! Check previous message for more info! Check battery, cable, charge! Before try again, check result! |
10-26-2015, 04:44 | #15 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Qualcom chinese phone.supported ? File conversion error, file already exists! Saved as default! problem in read flash file Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594815A1CBB8C7CFC5 [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_hexing75_jb.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : EBR2 [Image Ok] : system.img [Read Error] : Bad EXT data Looks like unusable file , break! Read Ok , collect info ProdName : GT-I9082 ProdModel : GT-I9082 Device : GT-I9082 AndroidVer: 4.2.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.MP.V1.16 File conversion error, file already exists! Saved as default! Done! Elapsed: 00:04:50 Reconnect Power/Cable! |
