11-14-2015, 09:27 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/Mediatek v1.37 - MT8163 Full Support, MT8127 NAND and more - Main changes MediaTek MT8163 ( Quad-core, x64 tablet CPU ) supported for wide range of service,repair and forensic operations! MT8163 mNAND and eMMC FlashIC types supported MediaTek MT8127 ( Quad-core tablet CPU ) with NAND FlashIC supported in test mode New CPU/Platform support - MT8163 eMMC - World First! Service: Read Info, Read Extended Info, Format FS, Fix DL , Repair ExtData UserLock: Read PatternLock, Reset UserLocks - Google, Pin, Password Other: Factory Reset Protection remove ( Google Reset Protection ) Forensic: PhoneBook extraction , Gallery Extraction Privacy Lock reset: Normal, Safe mode Read Factory Firmware (Scatter) Write Factory Firmware (Scatter) Read/Write Flash DUMP and NVRAM - MT8163 mNAND - World First! Service: Read Info, Format FS Privacy Lock reset Read Factory Firmware (Scatter) Read Flash DUMP and NVRAM SP Platform changes - Flash Engine updated MT8163 eMMC Flashing support activated Supported Platforms for Factory FW Flashing: MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6795 with eMMC MT8127/MT8163/MT87xx/MT83xx with eMMC - Factory FW Read improved MT8163 eMMC Factory FW reading supported! - WorldFirst! MT8163 mNAND Factory FW reading supported! - WorldFirst and Unique! MT8127 mNAND Factory FW reading supported! - WorldFirst and Unique! MT6571,MT6572 NAND: "Bad SYSData" issue solved for non-standard NAND configs Supported Platforms for Factory FW Reading: MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6795 with eMMC MT8127/MT8163/MT87xx/MT83xx with eMMC MT8127/MT8163/MT6571/MT6572 with NAND MT625A/MT6260/MT6261 with NOR SF - SmartAV engine updated Improved verification Now possible define AV setting by own requirements : Sense level and Limits - Other FlashInit DB updated: new flash ICs supported Boot logs now more informative Some other changes and bugfixes Official download link Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else - Infinity-Box - News Unlock Codes (Huawei, SE, Motorola, Samsung etc.), iPhone Unlock, Software Activations - Infinity-Box Online Service - Infinity-Box Dongle ready for delivery - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Telegram Last edited by YellowBoss; 11-14-2015 at 09:46. |
The Following 61 Users Say Thank You to YellowBoss For This Useful Post: |
11-14-2015, 10:00 | #4 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Sainath Mobile Solutions
Member: 2038392 Status: Offline Sonork: 100.1654462 Thanks Meter: 191 | Good update bt need stop button Sent from my SM-N900 using Tapatalk |
The Following 2 Users Say Thank You to sainathgsm For This Useful Post: |
11-14-2015, 10:14 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | some scatters files readed by other tools are shown as bad file, hence they are working fine with other tools. Kindly fix this issue, and add root option and adb tool too for resetting etc.. |
The Following 4 Users Say Thank You to zishhaider For This Useful Post: |
11-14-2015, 10:17 | #7 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Bootloader Locked phones not supported for now. Some phones supported after BL. Br. Hello, Tried to do Full factory reset with latest CM2MTK? I guess NO, so try and check yourself. BTW it's supported since v1.32 Br. | |
11-14-2015, 10:26 | #8 (permalink) | |
Scat files only supported which are read by CM2 itself or original ones. Scat read from other tools not supported so they show as bad file. This is not bug but CM2 is made this way. Root and adb not now. Resetting/format is supported without adb and root for most phones already. Br. | |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
11-14-2015, 11:08 | #11 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 289 | Ho Ho Ho Infinity Cmt Like Is Money Making Machine |
The Following User Says Thank You to asia_gsm For This Useful Post: |
11-14-2015, 11:51 | #13 (permalink) |
No Life Poster Join Date: May 2013 Location: Earth
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | helo team,we need stop button. please check about this just want to remove code through formating Card found : S/N : 995F...., v0129 Chinese Miracle II [MTK module] v 1.36 Operation : Format FileSystem [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 1FFF BB_CPU_HW : 1FFF BB_CPU_SW : 0000 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 00F36AC8E5CB9D1E344211C265FFCA84 BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! |
11-14-2015, 12:02 | #14 (permalink) |
Insane Poster Join Date: Aug 2011 Location: +254...
Member: 1644733 Status: Offline Thanks Meter: 33 | GREAT update By the way But where's the STOP button ??? Please INFINITY Team many CM2 Users Request for this option a Million times NOW !!! Y not just add it already ??? Because one has to Keep on closing The main Setup every time you need to Halt or close a process Last edited by samwaiyne; 11-14-2015 at 12:10. |
The Following 13 Users Say Thank You to samwaiyne For This Useful Post: |
11-14-2015, 12:57 | #15 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | plz supporte spd 8810 6820 format and writ pac file there ara many phones in market which ave this cpu plz we need full support for this |
The Following 3 Users Say Thank You to elpring For This Useful Post: |
