Old 02-28-2016, 06:31   #181 (permalink)
Member: 1211191
Thanks Meter: 44
i have lso same problem v1.41 is buggy i tried many set for format but fail
i tries to format many sets but fails 1.41
but 1.40 was ok
Originally Posted by byteforce View Post
New bug found in 1.41 while in 1.40 doesn't exist:
Same phone just exe differs.
1.41 bug
========================= Start =========================
                 2016-02-25 / 19:10:22
Card found : S/N : 79596BC6 , v0130
Chinese Miracle II  [MTK module] v 1.41
Start  at : [2016-02-25 / 19:10:48]
Operation : Format FileSystem [ v1.41 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 45010053454D3034473A53E5F0BC71F7
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D3034473A53E5F0BC71F7
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID    : D104F935308DA077E893B4874CA06F17
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Format/Reset Error!
Operation Failed
Elapsed: 00:00:30
Reconnect Power/Cable!
Finish at : [2016-02-25 / 19:11:19]
Start  at : [2016-02-25 / 19:11:29]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Format/Reset Error!
Operation Failed
Elapsed: 00:00:14
Finish at : [2016-02-25 / 19:11:43]
1.40 OK
Chinese Miracle II  [MTK module] v 1.40
Operation : Format FileSystem [ v1.40 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 45010053454D3034473A53E5F0BC71F7
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
[eMMC] : FLASH_VEN : 0045 , OEM : 0100
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 30 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:16
Old 02-28-2016, 15:53   #182 (permalink)
Member: 621121
Thanks Meter: 359
Walton PRIMO GM read done in 4.52 min
Operation : Read Flash
Operation : Read Flash [ v1.41 ]
Wait for phone...
Phone found! [ 65 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100513758534142014E67E612C17B
[eMMC] : FLASH_INF : [SAMSUNG] , BASX7
[eMMC] : FLASH_CID : 150100513758534142014E67E612C17B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 22D116439052E4684FE32EB906508A1D
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Brand     : Walton
ProdName  : Primo_GM
ProdModel : Primo_GM
Device    : Primo_GM
AndroidVer: 4.4.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.KK1.MP1.V2.11
[Read Ok] : preloader_techain82_wet_kk.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Make Ok] : cache.img
[Make Ok] : userdata.img
[ScatCFG] : MT6582 / V1.1.1 / techain82_wet_kk / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 1083 MiB
Scatter saved to : E:\All Flash file\Android\China\Walton\MT6582__Walton__Primo_GM__Primo_GM__4.4.2__ALPS.KK1.MP1.V2.11\
All done!
Done!
Elapsed: 00.04.52
Operation : Scan APPs
Operation : Scan APPs [DDirect] [ v1.41 ]
Wait for phone...
Phone found! [ 65 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
DDirect : Init Ok!
Scanning FileSystem now , please wait
[User Select] : Remove Files and Garbage
[DDCleaner Info] : Files to remove : 0
[DDCleaner Info] : Additional garbage detected : 0
Removing files ...
[DDCleaner] : Removed 0
Special Op #1 : Clear Recovery Data Ok!
Special Op #3 : PostFix Ok!
All Done!
Done!
Elapsed: 00.01.06
Old 02-29-2016, 11:24   #183 (permalink)
Member: 1362603
Sonork: prince
Thanks Meter: 5
my dongle dont have sp direct unlock
only NAND EMMC
HOW CAN I ACTIVATE MY DONGLE FOR MTK UNLOCKING
Old 02-29-2016, 11:43   #184 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,032
Enough select SP : Auto.
Unlock will be available in security tab.
Old 03-01-2016, 09:38   #185 (permalink)
naveedsialkoti's Avatar
Member: 2375239
Sonork: 100.1662985
Thanks Meter: 962
Q MOBILE X 90 IMEI REPAIR DONE
Old 03-01-2016, 21:17   #186 (permalink)
Member: 2501288
Thanks Meter: 303
read flash error in first time and in second time ok , pleas fix it
herbergeur d image
Old 03-01-2016, 21:29   #187 (permalink)
masterRt1994's Avatar
Member: 2105681
Sonork: Stoped Using...
Thanks Meter: 908
herbergeur d image
Your Antivirus Problem.
br
masterRt1994
The Following User Says Thank You to masterRt1994 For This Useful Post:
Old 03-01-2016, 21:42   #188 (permalink)
Member: 2501288
Thanks Meter: 303
br
masterRt1994
i already make it exclusion
image gratuite Ó tÚlÚcharger
what i do again
Old 03-02-2016, 06:55   #189 (permalink)
JayDi's Avatar
Member: 462970
Add whole Infinit-Box folder with all subdirs.
Old 03-02-2016, 10:05   #190 (permalink)
Member: 2501288
Thanks Meter: 303
Bro see in my picture already do it
Regards
Old 03-02-2016, 11:36   #191 (permalink)
JayDi's Avatar
Member: 462970
Regards
Then I have no idea, what to do more.
Old 03-02-2016, 11:47   #192 (permalink)
Member: 2501288
Thanks Meter: 303
I hope will be fixed in next update
Regards
Old 03-02-2016, 14:50   #193 (permalink)
Member: 2375239
Sonork: 100.1662985
Thanks Meter: 962
FIRST READ FLASH A GOOD WORKING MOBILE
OPPO R1001 HANG ON LOGO SOLVED WITH SIMPLY FLASH
Old 03-02-2016, 23:57   #194 (permalink)
Member: 168650
Thanks Meter: 5
Thumbs up [da_error] : Security_boot_not_accepted
Card found : S/N : 86D55A4D , v0130
Operation : Repair Security [ v1.41 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[DA_ERROR] : SECURITY_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:33
Old 03-04-2016, 00:58   #195 (permalink)
Member: 148515
Thanks Meter: 18,541
New version released - http://forum.gsmhosting.com/vbb/f296...fixes-2060693/
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.22979 seconds with 7 queries
