04-20-2018, 21:40 | #136 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 257 | |
The Following User Says Thank You to KrzychuG For This Useful Post: |
04-21-2018, 07:12 | #138 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Lake Mary (Orlando)
Member: 1016569 Status: Offline Thanks Meter: 229 | Quote:
Heartly thx for your reply here instead to concentrate on users complains rearding new update. 2nd thing is - may be i know better and enough knowledge as u complained / even u dam better know internal inside where u r wrong to build new update . 3rd thing is - you are notta only one coder in whole of world , So Be polite and concentrate on your job rather then killing time here . | |
The Following User Says Thank You to logicmobile For This Useful Post: |
04-21-2018, 07:17 | #140 (permalink) |
No Life Poster Join Date: Jul 2011 Location: dunia antah berantah
Member: 1616754 Status: Offline Thanks Meter: 246 | Meizu M2 Mini MT6735 CM2MTK Read Security NVram Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! CM2MT2 Operation : Read Security [ v2.00 r1 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! Use All Base still error use manual with Auth error too |
04-21-2018, 07:34 | #141 (permalink) |
No Life Poster Join Date: Dec 2003
Member: 46387 Status: Offline Thanks Meter: 139 | Code: Operation : Identify [ v2.00 r1 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Last edited by =CostyGSM=; 04-21-2018 at 07:39. |
04-21-2018, 07:45 | #142 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Probably there will be 2-3 old cpu (6573/6575/6583) not supported, or moved to new design. Rest all will be supported. | |
04-21-2018, 07:49 | #144 (permalink) |
Freak Poster Join Date: Jun 2008 Location: peshawar
Member: 784983 Status: Offline Sonork: 100.1676767 QQ 1125933349 Thanks Meter: 39 | Operation : Identify [ v2.00 r1 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT8163 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! |
04-21-2018, 07:50 | #145 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There were some issues on some machines. We are testing now fixes and will update sw, when test will be done. Quote:
Your device have 2 security levels - SBC and CERT. So you should use PL or PL_crypto type. Since have no idea what device it is - can't say exactly. | |
04-21-2018, 07:52 | #146 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Right now repair not supported. MT6763 have NEW security subsystem, not sure yet, but oppo made own level, or it MTK part - but device security paired to it UDID also. So, you can't clone other nvram as well. That is explained in release log as well. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
04-21-2018, 07:56 | #147 (permalink) | |
Last warning. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
