04-30-2018, 08:33 | #1 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Chinese Miracle-2 MTK/Mediatek v2.00 r2 - MT6739 support, SPUnlock and more As we told earlier, it was found some kind of problems with v2.00 at some PC and some hardware configuration. Current release should help to fix it. More details please see here - http://forum.gsmhosting.com/vbb/f296...tions-2386273/ More details about current release: - Main MT6739 CPU supported! MT6739 moved from TEST to GENERAL support. Firmwware read Firmware write NVRAM read NVRAM write Reset Settings / Format FS Reset FRP Reset Privacy MemoryTool - MemoryTool Fixed PMT init on some devices Optimized Expand/Collapse view functions Fixed DA1804 and DA1712 loaders support for WIPE Optimized NAND support - Service NVRAM module updated .dynamic page detection .some types support fixed .repair security ( security type detection ) updated FormatFS / Reset settings rebuild .Activated fully automatic "FULL FACTORY" mode, designed for all modern devices ( include devices with SEC_CONTROL ) ."FULL FACTORY" mode set to default .Some "OLD" agents (DA15xx) may not work - SP Unlock activated Support all MTK modern phones, except MT6763 and MT6739. Read codes and Direct Unlock mode supported MT6570 eMMC ONLY devices supported - Core Fixed memory leak issues and problems with booting on some systems Optimized different OLD agents support for MODERN devices ( DA16xx and DA17xx line ) SW more faster now EMI handler for MT6570 and MT6797 fully automated and complete Improved EMI lookup support for MT675x devices EMIDB updated Hint/Error explain module updated MT6758 support under test MT6771 support under test - Flasher Fixed break issue, when just one file selected for flashing. HWInfo compatibility status shown in log in both cases ( succes or failed ) - FW reader MT6739 support New types of firmwares supported Optimized NAND reading on DA18xx line loaders Read Firmware size now shown in log - New models included Limited MEIZU support Limited Oppo support Limited Gionee support Limited BQ support Some basic "generic" secure devices support optimized Known issues/warnings/info : 1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-Write data, which you want, ignore "EMPTY" states. 4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing 5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases! 7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list! Download link Upload file to Support Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News Twitter - Facebook - Telegram |
The Following 65 Users Say Thank You to YellowBoss For This Useful Post: |
04-30-2018, 08:39 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | moto x1721 i got this error -------------------------------- Operation : Identify [ v2.00 r2 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM1) MODE : PRELOADER PORT PORT : 1 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! |
The Following 5 Users Say Thank You to aashir For This Useful Post: |
04-30-2018, 08:58 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6739 test : http://forum.gsmhosting.com/vbb/f296...first-2387864/ |
The Following 17 Users Say Thank You to JayDi For This Useful Post: |
04-30-2018, 09:02 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6750 : ALCATEL 4049X : SP Unlock : Code: Operation : SP Unlock [ v2.00 r2 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x20000000 [ 512,00 MB ] EMMC: 1101003030344736300260716CA482AC EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 004G60 EMMC: BOOT1 : 0x00200000 [ 2,00 MB ] BOOT2 : 0x00200000 [ 2,00 MB ] RPMB : 0x00080000 [ 512,00 KB ] USER : 0xEC000000 [ 3,69 GB ] CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7755CF722D0C39C75756F32F4D008357 DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 256 | CNT : 5 | CODE : 32538347 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Direct unlock done! Done! Elapsed: 00:00:12 |
The Following 21 Users Say Thank You to JayDi For This Useful Post: |
04-30-2018, 09:44 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | MOTO/LENOVO K8 NOTE XT1902-3 MT6797 READ INFI & NVRAM READ Done SUCCESSFULLY READ INFO & NVRAM(MOTO/LENOVO K8 NOTE XT1902-3 MT6797)USB Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r2 THANKS INFINITY-BOX TEAM |
The Following 10 Users Say Thank You to gracy_elec For This Useful Post: |
04-30-2018, 11:31 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @Kwesi_Roy_GH, I had expect some caustiс/sarcastic comment. Do not ruin my hopes |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
04-30-2018, 12:35 | #10 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Surely, I'm not gonna ruin your hopes on this one my friend JayDi. I say it when it's good. I also say if it's bad. You need to get on with me bro... I'm always a neutral person. Good job done! |
The Following 3 Users Say Thank You to Kwesi_Roy_GH For This Useful Post: |
04-30-2018, 13:45 | #11 (permalink) | ||
Freak Poster Join Date: Apr 2013 Location: Pakistan Age: 24
Member: 1919988 Status: Offline Thanks Meter: 178 | unable to write nv Quote:
plz help here is log Quote:
The Following 2 Users Say Thank You to sindhi.aslam For This Useful Post: |
04-30-2018, 13:55 | #12 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Lenovo A7020a48 frp reset done thanks team Operation : Reset Settings/Format FS [ v2.00 r2 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A41E43C8E5A3A3 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3C275BED8C074945F1BBEE147495A384 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : PRIVACY Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to diesel6 For This Useful Post: |
04-30-2018, 14:03 | #13 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Good update JayDi. hope LEGACY on V2 will be activated soon... Last edited by -Mosin-; 04-30-2018 at 14:11. |
The Following 8 Users Say Thank You to -Mosin- For This Useful Post: |
