05-23-2018, 09:17 | #1 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Chinese Miracle-2 MTK/Mediatek v2.00 r3 - More secured devices and features! Chinese Miracle-2 MTK/Mediatek v2.00 r3 - More secured devices and features! - Main DownloadAgent version 1816 supported and tested on all supported SoC. Fixed some memory leaks Connection level revised - MemoryTool Fixed multi-selection GPT init revised Preloader init revised - Service Repair Security revised. Fixed issues with some Meizu and other models. - Core Optimized different agents versions support ( DA16xx line ) EMIDB updated Hint/Error explain module updated Activated SymLinks - allow reduce boot base size by redirecting diffirent brand/models if they have same base BootHelper ( stage 1 of 3 ) activated - hints/explanation of boot sequnce and correct file selection MT6758 support under test MT6771 support under test MT6765 support under test - Flasher Show Preloader HW compatibility when load firmware in flash tab Fixed file selection order - if SW package contain mixed types - secure will be selected by default - FW reader New types of firmwares supported Scatter creation optimized for some SoC - New models included Limited Alcatel support Limited Gionee support Limited Wiko support Limited Tecno support And diffirent other models Some other basic "generic" secure devices support optimized NAND devices on MT6570 moved to separate mode ( under base ) - FACTORY for ONLY FACTORY-provided FW flashing, INFINITY - for all rest operations Known issues/warnings/info : 1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-Write data, which you want, ignore "EMPTY" states. 4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing 5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases! 7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list! 8. [NAND on MT6570] In some cases device MAY DEAD after flashing! Make sure you have TESTED firmware version! If you have download FW from internet/other source - make sure it preloader CONTAIN 3 EMI record! Preloader jc45btlc with 2 records KILL SOME DEVICE TO UNRECOVERABLE STATE!!! Preloader info shown now during FW load. Credits : gracy_elec - different useful files contribution kamal_singla - testing and useful files contribution merujeffrey - useful files contribution and report logs Download From Official Support Area Index of pub//software/ |
The Following 17 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
05-23-2018, 10:46 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Oppo F7 Error Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
05-23-2018, 10:53 | #6 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA BROM : BOOTROM BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-23-2018, 12:53 | #7 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Pakistan Age: 24
Member: 1919988 Status: Offline Thanks Meter: 178 | waited for 1 month for r3 release but same error just like r2 Oppo CPH1725 old words http://forum.gsmhosting.com/vbb/13108145-post15.html Quote:
The Following User Says Thank You to sindhi.aslam For This Useful Post: |
