11-12-2014, 17:04 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Release) MTK/MediaTek v1.06 - MT65xx Repair security etc. MT65xx Repair security support and more MediaTek SP Platform .Cross CPU/Flash file checking ( not allow cross-flash different firmware ) .Repair Security options activated Tested and supported CPU: MT6571,MT6572,MT6575,MT6577 MT6582,MT6583,MT6589,MT6592 MT8312 series Support up to 4 IMEI repair Other: .Format FS procedure revised: backup/checking .FlashInit improved .Compile Info extraction improved .FlashID database updated .DebugLog reading enabled - for test/repair purposes MediaTek FP Platform .Repair Security operation improved .Support for 4th IMEI is activated Other: Drivers updated Some bugfixes and improvements First test-report: http://forum.gsmhosting.com/vbb/f296...-test-1878934/ Official download link: Index of pub/software/updates/ Infinity-Box 9 (nine) years (2005 - 2014) non-stop regular updates and support, as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Extract phonebook (and other content) from alive and dead phone - Follow us on Twitter |
The Following 9 Users Say Thank You to YellowBoss For This Useful Post: |
11-12-2014, 17:25 | #2 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
11-12-2014, 18:31 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I work on them, still can't collect enough phones for make all working as it should. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
11-12-2014, 18:56 | #7 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | I Can't Write Security On Karbonn A5s & A19 Code: Operation : Repair Security [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Show Like This On LCD Of Cellphone. ATE Signaling Test. Emergency call is not started. I Tried With Karbonn A5s & A19. |
11-12-2014, 19:15 | #9 (permalink) | ||
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Run dspinst from need , after repair security again. | ||
11-12-2014, 19:21 | #10 (permalink) | |||
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | MT6575 Read Flash Failed hi infinity Team, I just activate my support and download this new update. but it has a bug when it read full flash identify Quote:
Read Flash Quote:
Format user data Quote:
11-12-2014, 20:25 | #12 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | me phone i9500 dead after wrong flash possible to repair It ?? Card found: S/N 2296:0128 Chinese Miracle II [MTK module] v 1.06 Nothing to do , enter data , select fields Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D420042495E16C007 DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! Nothing to do , enter data , select fields Operation : Format FileSystem [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Open port error , something went wrong! Boot Error! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D420042495E16C007 DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Elapsed: 00:00:07 Reconnect Power/Cable! Nothing to do , enter data , select fields Nothing to do , enter data , select fields Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D420042495E16C007 DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
11-12-2014, 22:33 | #15 (permalink) | |
This software available for Main Infinity-Box users for now. Reason: [BEST] and CDMA - its a products for specific brands but Main Infinity-Box is a multibrand and universal tool. Probably activations will be available for BEST/CDMA users later but I can not promise anything right now. | |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
