12-22-2014, 19:05 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Release) MTK/MediaTek v1.08 released - Privacy Lock, Fix DL etc MTK SP (Android) eMMC: - Reset Privacy Lock (AntiTheft Lock) released - World First Allow reset "Privacy Protection Password" without FullFlash Erase, Destroying phone calibrations etc. Mostly used for MT6571/MT6572 phones - Fix DL option released - World First Allow fix "DL Tool Fail" and rest start-up errors after "Flash Write", "Format FS", "Reset PL" No need factory firmwares etc. That option allow now support original HTC, Acer, and some other brands with MTK65xx CPU - Format FS improved - FlashId database updated MTK SP (Android) NAND: - Improved "Read Info" operation - Improved "Read Flash" and "Format FS" operations - FlashId database updated Other changes: FlashInit improved Repair Security for MTK SP phones improved Other fixes and changes Special Thanks to Mr. Pradeep Kushwah for testing and samples ! Infinity-Box 9 (nine) years (2005 - 2014) non-stop regular updates and support, as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Extract phonebook (and other content) from alive and dead phone - Follow us on Twitter |
The Following 20 Users Say Thank You to YellowBoss For This Useful Post: |
12-22-2014, 19:31 | #2 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Android
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | hi sir sorry to say but i not understand when to use this option ( Fix DL option released - World First ) IN WHAT CONDITION OF PHONE WE HAVE TO USE THIS OPTION AND WHAT IS THE MEANING OF ( DL ) WANT TO KNOW |
The Following 2 Users Say Thank You to .::NIGAM::. For This Useful Post: |
12-22-2014, 19:45 | #5 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn A14 Privacy Lock Reset Done By Infinity CM2MTK Operation : Reset Privacy Lock [ v1.08 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447580FDB1F3D31D7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447580FDB1F3D31D7 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to MyGSM World For This Useful Post: |
12-22-2014, 19:54 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
I Detected On P2 But Cant Repair Security Setup Hangs On Repairing ..................... | |
12-22-2014, 20:11 | #10 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
After format FS, Flash Write , Reset PL - phone will NOT boot , until you not make Fix DL , or find factory firmware. With CM2 you can fix it for seconds without seek firmware and other headache. | |
The Following 4 Users Say Thank You to Dzirt For This Useful Post: |
12-22-2014, 20:16 | #12 (permalink) | |
Read Info Read Flash ( software show message what to do ) Read Flash again. Viola! Just 2 times need. And only for nand phones. And it will not be changed. So, if you not like such way - not use it. Security Repair - seems as some phones not correct work in AT mode. Now work going on 2 more modes - ADB and Meta. In some of next release it will be available. | |
12-22-2014, 20:18 | #13 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Code: Operation : Format FileSystem [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00C800F4000000000000000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0090 , [Gigadevice] GD5F4GQ4UAYIG [NAND] : FLASH_DIE : 00C8 00F4 0000 0000 0000 0001 0BC3 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block ERASE_CMD not allowed! Something wrong with HW or DA? Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! Last edited by shoaibrao; 12-22-2014 at 20:24. |
12-22-2014, 20:22 | #14 (permalink) | |
Its On P2 On Auto And P1 Setup Hangs Code: Operation : Check / Read Info [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00C800F4000000000000000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0090 , [Gigadevice] GD5F4GQ4UAYIG [NAND] : FLASH_DIE : 00C8 00F4 0000 0000 0000 0001 0BC3 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! | |
12-22-2014, 20:26 | #15 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | @shoaibrao , seems as you not understand, what you do at all. Identify = Read Info. Make read info. After it success - make Format FS - UDA+CACHE. If phone shows " ERASE_CMD not allowed !" - mostly that mean BAD NAND IC. Phone stuck, can't take photos, can't reset from settings, show invalid imei and e.t.c. |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
