GSMSERVER GSM Shop
Old 09-09-2015, 15:24   #1 (permalink)
Member: 148515
Thanks Meter: 16,692
Chinese Miracle-2 SPD/Spreadtrum v1.04 - New SPD Repair and Extra Features
Infinity-Box/Dongle Chinese Miracle-2 SPD/Spreadtrum v1.04 - New SPD Repair and Extra Features
Spreadtrum SC7715, SC7730, SC7731, SC5735, SC8830 with eMMC
Spreadtrum SC7715, SC8830 with NAND
New operations supported:
- Repair Security in FlashMode (allow low-level security repair) - WorldFirst !
*Allow fix phone security ( IMEI 1/2/3/4 ) in FlashMode
- Repair FS during "Format FS" (auto, if need)* - WorldFirst !
*Fix hang/stuck/bootloop and damaged after 3rd party tools
- Clear DIN data * - WorldFirst !
*Clear temporary phone settings and calibrations WITHOUT UserData lost !
Improvements:
- NV operations revised completely
NV Reading revised: Full NV data reading, checking and clear
NV Writing revised: Full NV data writing, clear and repair
NV writing also fix now all kind of network issues (software-related only)
NV writing also fix now "CFT calibrate" issue
NV writing also fix now "Unknown BaseBand" issue (software-related only)
TDMA phones (SC883x) support fixed
- Flash Engine updated
PAC file handling revised
Flash writing improved
- Check/Info revised
Shows extended phone info
Detect extra infromation (Dynamic HW Info check)
- Repair Security improved
Repair Security in "SVC" mode revised
- Some other bugfixes and improvements
Other:
FlashID database updated
Some bugfixes and improvements in FP Platform
Some other bugfixes and improvements at all
Official Download link
Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else - Infinity-Box - News
Unlock Codes (Huawei, SE, Motorola, Samsung etc.), iPhone Unlock, Software Activations - Infinity-Box Online Service
1. Infinity-Box Dongle ready for delivery
2. BB5 Easy Service Tool [BEST] Dongle
3. CDMA-Tool Dongle (fast and easy unlock)
Twitter Facebook
Are you programmer with experience in GSM/CDMA ?
Do you want to work with us ?
Contact to [email protected]
The Following 22 Users Say Thank You to InfinityHelp For This Useful Post:
Old 09-09-2015, 15:43   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,074
Videocon Vphone Grande read user code, Firmware and Format done-
Read user code-
Operation : Read User Code [ v1.04 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 24 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0060 0017 0000
[0] Flash VEN : Winbond , W25Q64
[0] Flash CAP : 00800000
Check data... Can take some time
User Code : 2015
Done!
Elapsed: 00:00:14
Reconnect Power/Cable!
Read Firmware-
Operation : Read FullFlash [ v1.04 ]
3. Insert battery
Phone found! [ 24 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Project  : SC6531_OPENPHONE
HWInfo   : SC6531_OPENPHONE
Compile  : 06-05-2014 17:07:30
Set FileInfo :
Model Vendor : Videocon
Model Name   : Vphone grande
ExtInfo Data : English
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_06052014170730_English__Videocon-Vphone grande_2.bin
Done!
Elapsed: 00:01:05
Safe Format-
Operation : Format File System [ v1.04 ]
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 24 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:18
The Following 3 Users Say Thank You to PASSIONATE_BOYS For This Useful Post:
Old 09-09-2015, 16:01   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,880
SC7731 , repair Security in FlashMode :
Operation : Repair Security [ v1.04 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7730/SC7731 loader eMMC v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Write new security data :
IMEI1 : 099467655556762
IMEI2 : 099433486666782
Step #1 Ok
Step #2 Ok
Step #3 Ok
Write done!
Elapsed: 00:00:26
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 09-09-2015, 16:03   #4 (permalink)
JayDi's Avatar
Member: 462970
SC7731 , new NVRAM read/write mode.
Operation : Read NV [ v1.04 ]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Read NVM Part #1
Part Ok
Read NVM Part #2
Part Ok
Saved to : C:\InfinityBox\CM2SPD\phdata\backup\CX7731_FLYIQ4505_SPDNV.spdnv
Elapsed: 00:00:55
Operation : Write NV [ v1.04 ]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
GSM Phone detected!
Write NVM Part #1 Ok!
Write NVM Part #2 Ok!
Write NVM Part #3 Ok!
Write NVM Part #4 Ok!
Clean DYNV
Clean DYNV Done!
Elapsed: 00:00:14
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-09-2015, 16:06   #5 (permalink)
JayDi's Avatar
Member: 462970
Read Extended Info :
Operation : Check/Read Info [ v1.04 ]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : FlyIQ4505
Model Brand : Fly
Model Device: IQ4505_Quad
AndrVersion : 4.4.2
BaseBand CPU: SP7731GEA
CompileDate : 1421754194
Project Ver : SW10_FLY_IQ4505 Quad_2015_01_20
Model Ext   : IQ4505 Quad
ExtraInfo : HWInfo not exists, normal phone
ExtraInfo : GSM Phone
Elapsed: 00:00:22
Another one example, where need be VERY accurate :
3. Insert cable
Phone found! [ 71 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name  : Q324
Model Brand : Micromax
Model Device: Q324
AndrVersion : 4.4.3
CompileDate : 1421379188
Project Ver : MMX_Q324_SW_1.2.4_HW_4.0.0_20150117
Model Ext   : Micromax Q324
ExtraInfo : HWInfo exists!!! This phone have DYNAMIC HW settings!!!
Elapsed: 00:00:22
Old 09-09-2015, 16:09   #6 (permalink)
JayDi's Avatar
Member: 462970
NAND phones Repair Security in FlashMode.
Yes, it work with ALL phones
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7715 Generic Loader NAND v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected NAND Flash , Structure detect Ok!
IMEI1 : 099644312778340
IMEI2 : 099644312778357
Step #1 Ok
Step #2 Ok
Step #3 Ok
Write done!
Elapsed: 00:00:17
The Following 7 Users Say Thank You to JayDi For This Useful Post:
Old 09-09-2015, 16:16   #7 (permalink)
Member: 2316752
Thanks Meter: 37
What is 'Din data'?
Plz explain..
Old 09-09-2015, 16:22   #8 (permalink)
Member: 220595
Thanks Meter: 272
Excellent update !
I have a sc7715, brand/model NIGA, it is Network Locked, will there be any chance cm2spd will SP Unlock these phones?
please consider making an NVRAM Database in support area, and consider this for MTK phones also.
Also would be good to have a preloaders database for MTK.
Old 09-09-2015, 16:34   #9 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by yurais View Post
Excellent update !
Hello.
Yes, I can unlock SC7715 phones (emmc at now, not have nand samples).
If you want help me - PM me with ReadInfo/Check log and NVM readout from this phone. Will check it and think about unlock.
About DB - yes, need start collect it. We work on that too.
Originally Posted by Mr Bikash View Post
What is 'Din data'?
Plz explain..
DIN - I call by this work temporary settings, which phone use on it work. Damage them may cause network problems, reboots , bootloop.. Now SPD module can reset them without need of flashing.
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-09-2015, 16:51   #10 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 456
@JayDi
Sir Will You Help Us For SPD 8810/6820 CPUs?
The Following User Says Thank You to shoaibrao For This Useful Post:
Old 09-09-2015, 17:11   #11 (permalink)
Member: 2393670
Thanks Meter: 10
hello to you infinity service !
when will suport : spd6820/8810 and SPD7710 and 7710G ?
when will suport SP UNLOCK of many phone spd :SPD 6531 ,6530,6820....
i have phone SPD SC7701B : need suport this cpu
i have phone SPD SC6531 (not original phone) : need SP UNLOCK (it block only with one sim)
my friend will go TO CHINA and need to give to you all phone !
can you TAKE ALL PHONE PLEASE?
GIVE ME YOUR NUMBER PHONE AND YOUR CONTRY AND CITY IF POSIBLE!
Old 09-09-2015, 17:19   #12 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by shoaibrao View Post
@JayDi
Hello. Yes, sure. Very soon
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 09-09-2015, 17:23   #13 (permalink)
JayDi's Avatar
Member: 462970
Hello.
If you want help us with SP locked samples - that would be great.
If you want help us with different SC770x and SC880x samples - that would be great.
Contact details and rest - pm me your skype/icq and we can discuss about all of that.
Old 09-09-2015, 19:06   #14 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,378
Better If Read Flash Also Given As Now Days China Market Expend We Don't Having All Model Factory For Service Phones... I Know Ur Solution Is Safe Risk Free But We Can't Take Risk & Customers Are Not Agree @ Dead Risk We Can't Bare PCB Price If Firmware Not Available... In Some Case Handset Came With Hang On Logo User Area Damage By Other By Using Other Tool Not Possible To Repair All Without File With Format Or Repair User Area So Kindly Add ASAP.
Anyways Good Update Keep It Up
Old 09-09-2015, 19:12   #15 (permalink)
Member: 1603029
Thanks Meter: 19
Please Add old spd cpu's like 6820, 6825, 8825 etc...
Page generated in 0.42067 seconds with 7 queries
