06-17-2014, 09:33 | #16 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Belarus, Gomel
Member: 739328 Status: Offline Thanks Meter: 27 | Samsung i9300 Code: Chinese Miracle II [MTK module] v 0.02 Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 22 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 685527CD88535BBA57885208C3033890 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:40 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 29 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 685527CD88535BBA57885208C3033890 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00750000-0x007FFFFF , LEN : 0x000B0000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:14 Reconnect Power/Cable! Code: Operation : Repair Security [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 29 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 685527CD88535BBA57885208C3033890 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6250 SW : R5001C_93_L2_V02 HW : RT50_6464_11B_HW IMEI[1] : 352012080850018 IMEI[2] : 352012080850018 Update IMEI[1] to : 3556*********** Done! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to desiderium82 For This Useful Post: |
06-17-2014, 10:35 | #17 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile E890 Repair Imei Done by Infinity Box |
The Following 2 Users Say Thank You to DUNIYA JAMAL For This Useful Post: |
06-17-2014, 13:24 | #24 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 1. I accept ONLY CM2MTK logs, other not interest for me at all. 2. Reset UserCode set it to Phone Default , and it can vary from 0000 , 1122, 1234 , 12345. Customer sure know it. If phone still ask code - repeat reset once more time and it must work. |
06-17-2014, 21:48 | #25 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Ecuador
Member: 205346 Status: Offline Thanks Meter: 26 | Alcatel 3035a not work operations....Dibujo.jpg |
06-18-2014, 07:00 | #29 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile g200 fully supported READ INFO Code: Operation : Check / Read Info [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : DA7F1BD52799E12975FEB0D79492A96F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:04 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : DA7F1BD52799E12975FEB0D79492A96F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002B6000-0x002FFFFF , LEN : 0x0004A000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Reset UserCode [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : DA7F1BD52799E12975FEB0D79492A96F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Backup exists , skip Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:46 Reconnect Power/Cable! Code: Operation : Repair Security [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : DA7F1BD52799E12975FEB0D79492A96F BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : R021_QMOBILE_V01.14_20131218 HW : R023_V01 IMEI[1] : 354485015672079 IMEI[2] : 354485015672079 Update IMEI[1] to : 359418050034447 Update IMEI[2] to : 359418050034439 Done! Done! Elapsed: 00:02:15 Reconnect Power/Cable! Code: Operation : Read Flash [ v0.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : DA7F1BD52799E12975FEB0D79492A96F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : R021_QMOBILE_PCB01_gsm_MT6260_S00.R021_QMOBILE_V01_14_20131218.bin FileVersion : R021_QMOBILE_V01.14_20131218 Saved to : C:\InfinityBox\CM2MTK\Read_out\R021_QMOBILE_PCB01_gsm_MT6260_S00.R021_QMOBILE_V01_14_20131218.bin Done! Elapsed: 00:00:19 Reconnect Power/Cable! Code: Chinese Miracle II [MTK module] v 0.02 Load File Load File File_Info : R021_QMOBILE_PCB01_gsm_MT6260_S00.R021_QMOBILE_V01_08_20130924.bin FileVersion : R021_QMOBILE_V01.08_20130924 Load File Ok Operation : Flash [ v0.02 ] ======= Flash Files set for flashing : [ MCU ] : qmobile g200 ok r021_qmobile_pcb01_gsm_mt6260_s00.r021_qmobile_v01_08_20130924.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : DA7F1BD52799E12975FEB0D79492A96F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Erase region , wait ... Write data , wait ... Write : qmobile g200 ok r021_qmobile_pcb01_gsm_mt6260_s00.r021_qmobile_v01_08_20130924.bin Done! Elapsed: 00:00:55 Reconnect Power/Cable! http://forum.gsmhosting.com/vbb/f425...l#post10382734 |
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
