04-30-2014, 06:57 | #18 (permalink) | ||
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | blueberry S111 Read flash and format without tension. Read Flash Quote:
Siddeque. | ||
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
04-30-2014, 07:38 | #23 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ATI atheeq technical(srilanka)
Member: 709520 Status: Offline Thanks Meter: 275 | PHONE IS ON PHONE LOCK . READ CODE, FORMAT FAILED ==== Wait for phone... Phone found! [ 278 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Check data... Can take some time User Code : Active Code not found (Standard : 1234 , 0000 , 1122) Operation : Format File System Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 278 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C8 0060 0018 0000 Flash VEN : GigaDevice , GD25LQ128 Flash CAP : 01000000 Verify data... Can take some time Error while prepare! Format error, something went wrong |
04-30-2014, 07:49 | #24 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,927 | Chinese Miracle-2 (Test Version) SPD/Spreadtrum v0.02 released .Supported CPU: SPD6530, SPD6531 .Supported Interface: USB, COM/UART .Supported FlashIc: 4/8/16/32 Mb .Supported operations: 1. Read Info 2. Check 3. Flash Read (Plain Bin) 4. Flash Write (Plain Bin) 5. Read UserCode 6. Repair IMEI 7. Format/Reset Settings |
04-30-2014, 08:51 | #28 (permalink) |
Insane Poster Join Date: Jul 2005 Location: india
Member: 160069 Status: Offline Sonork: 100.1622432 Thanks Meter: 30 | Phone found! [ 128 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00EF 0040 0016 0000 Flash VEN : Winbond , W25Q32 Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:19 karbonn k72+ format and code read success no dead risk at all... really a great update by infinity team |
04-30-2014, 09:00 | #29 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
04-30-2014, 10:16 | #30 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,927 | Chinese Miracle-2 (Test Version) SPD/Spreadtrum v0.03 released .Improved Flash detection .Improved UserCode reading for some original brands (Explay, Phillips) .Improved Format/Reset setting for some original brands (Explay, Phillips) .Improved Dual-Type structure support (16mb Touch phones) .Improved Repair Security (No Ack Error) on some phones .Minor bugs fixed |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
