Old 05-14-2014, 14:41   #151 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
@Kirumira , pm me your ICQ , will try something tomorrow.
Old 05-14-2014, 21:27   #152 (permalink)
Member: 1043909
Thanks Meter: 60,926
Dear Friends !
If you will send any flash files to Mr. Dzirt, please, send a copy to [email protected] or to [email protected] so we will be able to upload fkkash files into support area.
Thank you !
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 05-14-2014, 22:47   #153 (permalink)
Member: 154448
Sonork: not yet
Thanks Meter: 50
thank for infinity team in that update
Old 05-15-2014, 07:21   #154 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 318
pel 60 successfully format
The Following User Says Thank You to aashir For This Useful Post:
Old 05-15-2014, 10:12   #155 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
Karbonn K111* Sucessfully recover
Operation : Check/Read Info
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 14 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0000
Flash DIE : 00EF 0040 0016 0000
Flash VEN : Winbond , W25Q32
Flash CAP : 00400000
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
Operation : Format File System
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 14 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:36
Thanx Team
this is my 1st test report //lots coming through
The Following User Says Thank You to jmzboudh For This Useful Post:
Old 05-15-2014, 11:52   #156 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Originally Posted by YellowBoss View Post
Dear Friends !
Thank you !
Hello there some files for download
http://forum.gsmhosting.com/vbb/f296...0/index13.html
The Following User Says Thank You to Kirumira For This Useful Post:
Old 05-16-2014, 04:37   #157 (permalink)
Member: 264930
Thanks Meter: 3
hi, samsung e3300i erika is supported?? cuz i try to unlock but i can't... somethin special i have to do??
Old 05-16-2014, 05:15   #158 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Should, if it SPD based. Post with logs.
Old 05-16-2014, 13:44   #159 (permalink)
Member: 264930
Thanks Meter: 3
hi, is SPD based, but i can't conect them, for that my question, i need to do something special for unlock?
Old 05-16-2014, 14:20   #160 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Depend what you want unlock : User code or SP code.
Connect - need have modified cable ( check in docs ) or proper bootkey.
All explained in docs folder about that things.
Old 05-16-2014, 15:21   #161 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Mr Dzirt Is the File ready SIR? Send it to [email protected]
Old 05-16-2014, 15:47   #162 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Kirumira , trying finish.
One question - does phone asks for unlock code, or just not show network or show something other? Like : Invalid Sim , or Sim Error ?
Old 05-16-2014, 16:21   #163 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
Disko 5282 Screen Lock Done Via Format (Chines)
Read Flash
Chinese Miracle II  [SPD module] v 0.04
Operation : Read FullFlash
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Flash DIE : 00C8 0060 0017 0000
Flash VEN : GigaDevice , GD25LQ64
Flash CAP : 00800000
Read Flash Content
Read Ok , collect info
Platform : MOCOR_12B_6531.W13.07_Release
Project  : SC6716_PDA
HWInfo   : SC6716_PDA
Compile  : 11-27-2013 11:25:59
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_11272013112559.bin
Done!
Elapsed: 00:01:45
Format FFS
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:18
Dump Uploaded On Support !!
The Following User Says Thank You to pradeep_kus For This Useful Post:
Old 05-16-2014, 16:29   #164 (permalink)
Member: 459784
Thanks Meter: 1,543
hi bro
which cpu inside do you know? pls post full info
6610-20
6530
6531
L7
L2
6820
8810?
Old 05-16-2014, 17:47   #165 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 235
The Following User Says Thank You to m&s For This Useful Post:
Page generated in 0.26675 seconds with 9 queries
