12-08-2015, 07:11 | #586 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | KECHAODA K27 Call Log Not working slove by format Code: Operation : Check/Read Info [ v1.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 174 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Elapsed: 00:00:21 Reconnect Power/Cable! Code: Operation : Read NV [ v1.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 174 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Check data ... Reading NV ... Saved to : C:\InfinityBox\CM2SPD\phdata\backup\6531_NV_00008000_Kechaoda K27.nv Elapsed: 00:00:28 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 174 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : Kechaoda Model Name : K27 ExtInfo Data : ENG Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32_ENG__Kechaoda-K27.bin Done! Elapsed: 00:00:43 Reconnect Power/Cable! Code: Operation : Format File System [ v1.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 174 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
02-29-2016, 09:06 | #589 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
If You This Model Flash File PLEASE Upload Here Thanks & Regards By: Gopal Parmar | |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
09-09-2016, 15:36 | #592 (permalink) |
Freak Poster Join Date: Apr 2016 Location: At Your Home
Member: 2564038 Status: Offline Sonork: 100.1674499 Thanks Meter: 157 | My Chines miracle 2 spd 1.21 version not open Hello infinity team My Chines Miracle 2 Working Fine All Module Full Working But SPD 1.21 module not open old SPD module working how to solve this problem please guaide me |
09-09-2016, 15:41 | #594 (permalink) |
Member: 2564038 Status: Offline Sonork: 100.1674499 Thanks Meter: 157 | |
09-10-2016, 16:34 | #599 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: Abidjan Age: 38
Member: 1418143 Status: Offline Thanks Meter: 353 | I can't Read or Frp nor anything with SPD , I posted 9.08.2016 none car Quote:
