Old 02-12-2009, 23:52   #1 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Chinese Miracle killed a JinPeng C3000
That was a good working phone. I read the firmware succesfully, but when I try to write back, Chinese Miracle reports flash write error. Whole flash chip or other format methods can be processed succesfully. I downloaded the firmware for this phone from support area, but the same result. I tried to connect with test point inside, but same result. I tried to use Spiderman and Infinity PinFinder too for flashing. The flash chip is empty now because the whole flash formatting. This is the log of my last trying:
COM14 [VCP1] selected
module v2.76
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8C03:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000000:FFFFFF00000000
flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
.damaged firmware
.damaged hardware
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
error: error# 0000FFFF
error: flash write error: 00000000:00002000
Write Fail
Finished, time used: 143 sec
Remove/Install battery now !
After flashing hundrets of mobile phones with Chinese Miracle, this was the first occasion, when it killed a phone. Please, help me.
Old 02-13-2009, 14:38   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
This phone has a new flash chip type, programmers working about this problem.
If you can send to us this phone for detailed research please contact to [email protected]
Old 02-13-2009, 23:40   #3 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
I hope so, you can solve this problem quickly. The same thing happened today with another phone. Unfortunately, both of them came from customers for language translation. So, I can't send them to you, because thei're not mine.
Old 02-14-2009, 13:42   #4 (permalink)
Member: 130995
Hello,
If somebody can send to us phone with the same flash type for detailed research. please contact to [email protected]
Old 02-14-2009, 14:00   #5 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
I can't send these phones, but maybe can make some research. What do you need to know?
Old 02-14-2009, 21:51   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
unfortunately, remote tests are not possible
Old 02-14-2009, 22:48   #7 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Now, here is the third phone with the same error, but in this case I have 3 phones from the same kind, bought together. I flashed properly 2 phones, but the third flashing stopped with the same error like the earlier. The firmware of the 2 properly flashed phones made in 12th. december 2008, the error flashed phone firmware is from 7th. january 2009. This phone is mine, so I can send it to you, if needed. These are some Ming Xing A008.
Old 02-14-2009, 22:56   #8 (permalink)
Member: 148515
hello!
please post operation log of that phone which you can send us
Old 02-14-2009, 23:12   #9 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Here's the log of my last trying:
COM14 [VCP3] selected
module v2.77
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:E603:0001
status: FF
Boot Done
Initialize ...
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
.damaged firmware
.damaged hardware
Write ...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
Write Fail
Finished, time used: 149 sec
Old 02-15-2009, 14:26   #10 (permalink)
Member: 148515
hello!
yes, we need this phone.
Please contact me by email : [email protected] for discussing details
Old 02-20-2009, 02:08   #11 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Here is the 4th phone I found with the same flash write error. Here's the downloaded firmware: http://rapidshare.com/files/20018631..._.B0M.bin.html
module v2.77
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:E803:000C
status: FF
Boot Done
Initialize ...
flash: 98000300000000:18E59F00000000
Initialize Done
Set baud ...
460800
Set baud Done
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.77, database date: 14.02.2009):
TL_T838_P37U07F09L72_01_41.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: TL_T838_P37U07F09L72_01_41.BIN
ver. sw 2: TL_T838_P37U07F09L72_01.41, 00000000
ffs offset/size: 00E00000/00200000
Write ...
Area: Firmware
Write: Firmware
error: flash write error: 00600000:00002000
Write Fail
Finished, time used: 104 sec
The Following 2 Users Say Thank You to bencebacsi For This Useful Post:
Old 02-21-2009, 14:53   #12 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
5th phone with the same flash write error. This is a popular TV-N99i. The firmware is the same as at others with older, good working flash chip.
module v2.77
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0303:0000
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
TV100_PCB01_GPRS_MT6225_S00.ZZT_TV100P12_5_2T03D01 11_MB01.BIN
ver. sw 1: TV100_PCB01_GPRS_MT6225_S00.ZZT_TV100P12_5_2T03D01 11_MB01.BIN
ver. sw 2: ZZT.TV100P12.5.2T03D0111_MB01, 00000000
Write ...
Area: Firmware
Write: Firmware
error: flash write error: 005C0000:00002000
Write Fail
Finished, time used: 113 sec
Old 02-22-2009, 16:12   #13 (permalink)
Member: 148515
hello!
thank you!
phone recieved, we started to work.
Old 02-23-2009, 20:25   #14 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Hi,
I hope so, you'll find the solution soon, because I found the 6th phone with this problem. Actually, I try to boot the phones with spidermen instead of brick them by CM flashing. If the boot process fails beause "Unsupported NOR Flash Type", I don't try to flash that phone by CM, just download its firmware.
Old 02-23-2009, 21:02   #15 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
I'm just wondering on that, no other users report this problem, when I experience this in more and more cases. I don't think so, these faults was caused by my system, because still all goes well with most firmwares, and other flasher softwares absolutly can not operate these flash chips. Only Chinese Miracle can if only read the content of these chips.
Jinpeng C3000 bmster89 Chinese Models & Cloned Phones 1 01-07-2016 06:24
Chinese Miracle cable set, where?? armkbdotcom Infinity-Box 34 03-02-2008 11:45
motorola F3 chinese miracle? mrfixit Infinity-Box 3 02-19-2007 22:25
Chinese Miracle cable set needed ASAP armkbdotcom Wanted Products 1 01-19-2007 02:55
Chinese miracle telsda mp4?? T6012 SLIPLOCK Infinity-Box 4 01-11-2007 00:17
Page generated in 0.33151 seconds with 10 queries
