Chinese model no.1288 ANALOG TV MOBILE pin out neded. chinese 1288 tv mobile pinout nedded.................. |
hello! if you really expect some help from other infinity users- please post full data of your phone. right now very important thing is missing: phone connector type. also would be great to know which pin is GND |
urx vbat powerkey ground but my quetsion is what model select in shell BR |
You need to select "Chinese-Miracle" -> "MT62xx-CPU-based-model" |
COM4 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 Connecting, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: U6V10B19 Version: U6_HW detecting structure #2... warning: wrong packet cs warning: wrong packet cs done 60 byte(s) read warning: wrong packet cs imei: 35009273399844 warning: wrong packet cs connection Ok detecting structure #1... warning: wrong packet cs warning: wrong packet cs done 208 byte(s) read warning: wrong packet cs Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1524 Finished, time used: 18 sec Remove/Install battery now ! |
and me too i have problem with this phone dead after format pls help flash file and what the the phone type may i use to flash? pls help sir thanx infinity team |
try complete format option and try to power on it with power button preesed for approx 1 min. if u need flash file just post here the firmware version u need |
2. What is original firmware version ? 3. Do you have full flash backup before format ? |
no i don,t have..what can you help? |
please open operation.log file and post here full firmware version |
