05-18-2008, 22:37 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Chinese models with Infineon CPU If you have new models with Infinieon CPU (f.e. 7880), we can try to support these models. What to do: 1. Run Infinity-Box "Pana01" module 2. Select "LG KG375" model 3. Read full flash 4. send the next information to [email protected] 4.1. phone model name and CPU chip name 4.2. pinout information 4.3. "operation.log" file 4.4. full backup file We will check your information and will try to add new model |
The Following 29 Users Say Thank You to InfinitySupport For This Useful Post: |
05-19-2008, 05:49 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
05-19-2008, 19:36 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @SHOEB AHMED @elkawasmy Current thread is about Infineon CPU, if you have anything to write regarding this topic, please write, in other case, please, write in other threads |
05-19-2008, 20:36 | #7 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | i have NOKLA E90 already send may can faster supported infineon cpu step : 1. Run Infinity-Box "Pana01" module 2. Select "I-Mobile 100" model 3. Read full flash 4. send the next information to [email protected] txs |
05-21-2008, 13:07 | #9 (permalink) |
No Life Poster Join Date: Apr 2004 Location: nagaur raj Age: 57
Member: 62820 Status: Offline Thanks Meter: 175 | dir sir, here is log detail flash file send to u with photo here is pinfinder log software version: 1.09 cable type: 1x8 (L8A) platform: PMB: Infineon e-gold searching adapter at COM7... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (820000) result: Rx:3 Tx:4 time required: 7 sec Power On ! and here is readed with pana01.exe log Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.47 S/N: 08A7:010E Wait... Current model: LG KG289 Ready Current model: LG KG275 COM7 [VCP0] selected Device: LG KG275 Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG275_eeprom-sta_20080521-165453.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG275_eeprom-sec_20080521-165457.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG275_eeprom-complete_20080521-165507.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG275_flash_20080521-170129.B1X.bin completed Finished, Remove/Install battery now ! |
05-21-2008, 20:34 | #13 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Egypt Age: 42
Member: 113200 Status: Offline Sonork: 100.1573773 Thanks Meter: 87 | Hi Infinty Team, i have phone (ZTC ZT9288) i found pinouts by pin-finder but i cant read flash like u said look at pic no.2 it cant boot whats the problem??? Br, Elkawasmy |
05-21-2008, 21:48 | #14 (permalink) | |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | are u have try Quote:
how to unlock chinese phone with infineon CPU | KUBAT1 | Infinity-Box | 7 | 02-14-2010 13:03 |
again this is unlocking log of chinese nokia 1112 with infineon cpu 7880 | jacob magembe | Infinity-Box | 0 | 01-21-2010 11:00 |
chinese nokia 1112 with infineon cpu | jacob magembe | Infinity-Box | 0 | 01-21-2010 10:32 |
We are looking for Full Flash Files read from Chinese Phones with Infineon CPU | nonu_don | ET-BoX | 8 | 10-16-2008 12:09 |
How to Work with Infineon cpu | memobiles | Infinity-Box | 2 | 09-28-2008 13:06 |
