Old 11-28-2007, 10:21   #1 (permalink)
maheshsaiganesh's Avatar
Member: 289913
Thanks Meter: 125
chinese N77i format ffs succesfuly done
COM1 selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
chip: 0031:7B09:15F5
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] (or higher) generation
security area#1 Ok
security area backup saved: id.FF796FBC.[ZL32L_THL_PCB01_GPRS_MT6226_S01.ZL32L_THL1_6.BIN_7 7AEE5B9].rpl
identification#1 detection finished
device-id: FF796FBC
identification#1 protocol ver: 04
ver. sw1: ZL32L_THL_PCB01_GPRS_MT6226_S01.ZL32L_THL1_6.BIN
ver. sw2: ZL32L_THL1.6
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
reading [eeprom[ZL32L_THL_PCB01_GPRS_MT6226_S01.ZL32L_THL1_6.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\n77i
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log_FF796FBC_ZL32L_THL_PCB01_GPRS_MT 6226_S01.ZL32L_THL1_6.BIN_77AEE5B9_20071128-144235.B0X.bin
Finished, time used: 266 sec
Remove/Install battery now !
Old 11-28-2007, 13:17   #2 (permalink)
Member: 130995
Thanks Meter: 35,157
Thank you for good test report !
Old 12-02-2007, 16:00   #3 (permalink)
randr's Avatar
Member: 73323
Sonork: 1001664281
Thanks Meter: 68
pls tell me which cable to use for this modal
Old 12-02-2007, 16:03   #4 (permalink)
randr's Avatar
Member: 73323
Sonork: 1001664281
Thanks Meter: 68
I have chines cable set for infinity and ub but in that n95 slider cable is only works other cables are not detecting phones n95 18 pin pls tell me i have to modify the cables pls or pls give me the nos off cable which is which phones
thanks
Old 12-05-2007, 12:25   #5 (permalink)
Member: 93610
Thanks Meter: 45
Originally Posted by maheshsaiganesh View Post
COM1 selected
Action: reset
Boot...
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
security area#1 Ok
device-id: FF796FBC
eeprom chip: 00
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
Hio mates i have also N77 its pinout 6*2 cable please can u give me cable pinout for N77
THANKS
NASMI
Old 12-17-2007, 12:03   #6 (permalink)
LePilami's Avatar
Member: 444025
Thanks Meter: 25
i have one too but 1..........18 conector.
Please poste the right pinout
Old 12-17-2007, 12:09   #7 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
Post the Pinouts Also there bro ...........................................
Old 12-17-2007, 19:04   #8 (permalink)
communication_expert's Avatar
Member: 50511
Sonork: 100.109684
Thanks Meter: 307
good for testing and replay thats a nice report and
and this is a pinouts n77 complete collection .
keyboard top
1..........8
3: Rx
4: Tx
5: Gnd
keyboard top
1.........12
1: Gnd
7: Tx
8: Rx
keyboard top
connector_2x6
3: Tx
7: Gnd
10: Rx
keyboard top
connector_2x6
4: Rx
5: Tx
6: Gnd
connector 2x7
13: Gnd
14: Gnd
7: Tx
8: Rx
The Following User Says Thank You to communication_expert For This Useful Post:
Old 12-17-2007, 20:45   #9 (permalink)
Member: 643285
Thanks Meter: 11
N77 24 pins
can u help me please
i have nokia chinese N77 24 pins like LG8xxx
can u send me pinout
thx
Old 12-18-2007, 22:52   #10 (permalink)
Member: 116644
Thanks Meter: 10
i have nokia chinese N77 2x5 pins
thanks
Old 12-19-2007, 08:39   #11 (permalink)
Member: 130995
thanks
Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts),
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 12-19-2007, 12:35   #12 (permalink)
Member: 95613
Thanks Meter: 17
N77 2x5 pin out is 4 rx 5 tx 6 gnd tested by mi 1000/1000 but to writ ime you muste yous mode 2 tested by mi...........keep worken
Old 12-19-2007, 22:37   #13 (permalink)
Member: 116644
Thanks Meter: 10
Thanks Halim2001 for your Help
Old 12-27-2007, 06:35   #14 (permalink)
elkawasmy's Avatar
Member: 113200
Sonork: 100.1573773
Thanks Meter: 87
Thanks for your Help
Old 12-29-2007, 22:24   #15 (permalink)
Member: 643285
Thanks Meter: 11
what about N77 24 pins like LG8xxxt
FORMAT FFS on chinese phone VIA microbox khem Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 05-08-2009 20:31
6300 after format ffs back to chinese language topnoyze Infinity-Box 4 10-11-2008 22:20
Chinese SEDx689 format ffs succesfuly ok. maheshsaiganesh Infinity-Box 1 11-28-2007 13:16
Chinese N73 Format Ffs Ok With Infinity sahil2000ind Infinity-Box 3 09-24-2007 10:21
chinese miracle phone after format ffs dead taleb_nazari Infinity-Box 5 09-24-2007 08:47
Page generated in 0.23587 seconds with 9 queries
