Chinese N95 pinout Hi, I have got one Chinese N95 with user code locked and I have to unlock that. But I m confused about the actual pinout. It is of 2x6 type mini connector. Quote:
<<n.b.: I already successfully made two cables for PANTECH & I-MOBILE>> With best regards, nishaon |
hello! use standart pin count |
Thanks for your quick reply. By the by, can u please tell us why chinese/russian pin count are given? With best regards, nishaon |
hey pls help me i cant connect my phone through pc can you give the installer of CECT N95 MT6227 pls S560.... pls pls |
chinese n95 pinout hello infinity what pinout i maintain i dont know what is standard pin out |
hello! this is standart pin count: standard pin count __________________ / 1 2 3 4 5 6 \ | 7 8 9 10 11 12 | 1: 2: Vcc 3: Vcc 4: USB D+ 5: USB D- 6: Rx 7: Tx 8: Gnd 9: HF ear 10: HF ear 11: HF mic you need pins 6,7,8 to make serial cable |
Please Help For 1*12 Standerd Pinout Need help about 1x12 Standerd Pinout. Cant catagorised the Set Models cause All comes in different Name Like Nokia N95, N95i, Vpower, V2, N73i etc. I use MTK Box for Cables and Infinity For Software. There is no 1x12 Cable with MTK so need a standerd pinout of 1X12 Cable Thank U. And Sorry for my Bad English. |
i have now n73 .. connector in the top of the LCD... i tried to change the Rx and Tx also... but same result... is there any other pinout for N73.. thanks siir.. |
Hello, Please, use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 |
Thanks for the quick reply, Its rsurely helps. I find the standerd TX reading - 2.5 - 2.8V and RX about 2.2 - 2.4V. Its been easy to repair chinese Sets with out any cable. Thank u very much. |
