Old 12-08-2007, 15:19   #1 (permalink)
farshid-jan's Avatar
Member: 306118
Thanks Meter: 192
where is eeprom KG300
LG KG300 after format dead
i cant find eeprom file in infinity soppurt
where is it?
Tanks
Old 12-09-2007, 12:24   #2 (permalink)
Member: 306118
Thanks Meter: 192
anybody here??
i cant find eeprom file for LG KG300 in infinity soppurt
I want repair eeprom but cant find these in soppurt
Old 12-09-2007, 14:25   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try long press to power button
about 30-40 sec
Old 12-10-2007, 19:40   #4 (permalink)
Member: 306118
Thanks Meter: 192
not feasible & no power with this
i cant format it
COM8 [VCP0] selected
Action: reset settings
Model: LG KG300
Checking data, wait...
19200
Initializing[6227:8A02:8A01]...
chip: 0031:E9C1:6FCE
Connecting, wait...
error: can't finalize test mide
repeat operation and HOLD phone "Power" button long time !
Operation failed !
Finished, time used: 23 sec
Remove/Install battery now !
& I cant flash it
Boot Done
Initialize...
flash: 98004900000001:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
Identification Fail
Finished, time used: 13 sec
Old 12-10-2007, 19:44   #5 (permalink)
Member: 306118
Thanks Meter: 192
i cant format it never again
Model: LG KG300
19200
Connecting, wait...
Operation failed !
& I cant flash it
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
Identification Fail
Tested MMODULE v1.71 too but no power on
Old 12-10-2007, 20:25   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
How it was happened that you can format phone first time and now you can't connect phone even for flashing ?
KG300 can be booted even with completely empty/erased flash chip, so if you can't boot or flash phone this means that you have empty battery or bad cable or phone hardware is faulty.
Old 12-11-2007, 17:07   #7 (permalink)
Member: 306118
Thanks Meter: 192
i don t Know
i tested it with power supply & without cable ( with pinout )
this is info of ( read detailed Information) in service [/B]
Boot Done
Initialize...
Initialize Done
Set baud...
460800
Set baud Done
Identification...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1B.BIN
ver. sw2: 7S7312SA00-001-R1B
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
Finished, time used: 22 sec
where is 2700 c-2 ngaia MXKEY Nokia Flasher and Unlocker (by Alim Hape) 11 04-12-2010 08:15
Where is A800 eeprom ic located?where the located? External hooi76 VLSI, Conexant, Skyworks and Old Models 2 03-03-2005 14:47
Where is eeprom in Xenium 9@9 TCD998 fm-gsm Philips 3 12-26-2001 03:38
Where is EEPROM in R210 ? majid VLSI, Conexant, Skyworks and Old Models 0 12-25-2001 18:23
Where is eeprom b.werrell Old Ericsson Phones & Sony Phones 0 09-15-2000 22:10
Page generated in 0.24280 seconds with 9 queries
