07-31-2008, 13:30 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | 6300 Erase IMEI itself, after change IMEI!! I tried many thing like complete format, flash nothing help, this is not just one hone, so it is not hardware problem.. many phones has the same problem.. plse take care about this problem infinity team.. regards.. |
08-02-2008, 10:14 | #3 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | What is phone firmware version ? JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN What is flash chip type ? CPU : MT6225A FLASH IC : SPANSION 71PL127NB0HFW4U detailed information listed below Did you tried to reball flash chip ? this is not a hardware problem, this type of phones all makes this problem. one of my friend (dealer) has many that phone with same problem in hand. That's why asking you. COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3303:0004 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.323E78B3.[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_E70F29F2].rpl identification#1 detection finished device-id: 323E78B3 identification#1 protocol ver: 04 ver. sw1: JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN ver. sw2: MAUI.07A.W07.52.MP.V2, 0DD6F018 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ........................ detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ........................ detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_323E78 B3_JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_M P_V2.BIN_E70F29F2_20080802-121349.B0X.bin Finished, time used: 150 sec Remove/Install battery now ! |
08-02-2008, 10:18 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Did you tried to find and use any other similar firmware for this type of phones ? Just an idea: phone firmware that you talk about has a bug and as a result phone eeprom become damaged after some time. |
11-23-2008, 19:50 | #10 (permalink) |
Freak Poster Join Date: Dec 2002 Location: south africa
Member: 18418 Status: Offline Thanks Meter: 8 | This is the firmware of the phone JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN. Please give me another firmware close to this that will work on this phone. |
11-23-2008, 19:58 | #11 (permalink) |
Freak Poster Join Date: Jun 2003 Location: TEKNOZER of TURKEY Age: 48
Member: 32738 Status: Offline Thanks Meter: 32 | if change imei number from flash file (16 Mb) and format all is ok . but this solution a long time so we need short time solution thanks infinity team .. |
11-30-2008, 23:59 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If problem still exist there is a way: use ChineseMiracle v2.70 and repair "imei inside firmware". After this operation even if imei will be resetted automatically it will be resetted to value that you already programmed. |
Nokia 6300 will reboot itself after 3 min | jorey | Nokia Hardware & Hardware Repair | 2 | 01-28-2010 09:01 |
6300 still contact service after write imei backup | black snake | MT-BOX | 9 | 10-14-2007 23:21 |
Can't call after change IMEI. | Alex1234 | VLSI, Conexant, Skyworks and Old Models | 14 | 12-10-2003 05:52 |
J70 after change IMEI from 0000 to normal, phone still says SIM LOCKED | dannyogolo | Sony | 10 | 09-02-2003 13:36 |
IMPOSSIBLE to reset security code after change IMEI !!!! | hanoon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 03-01-2002 18:09 |
