08-20-2008, 08:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Searchig.....
Member: 573543 Status: Offline Sonork: 100.1602019 Thanks Meter: 97 | G2288 boot problem I have 1 G2288 model handset when i coonect the infinity its showing boot error. some time handset boot is ok but no luck i have 2 piece. 1. security lock,2. only welcome mode. COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: M6205_PCB01_GSM_MT6205B_DN.Z6_TTK_N81_ML_6205V01_0 1B03.BIN ver. sw2: Z6_TTK_N81_ML_6205v01.01b03, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[M6205_PCB01_GSM_MT6205B_DN.Z6_TTK_N81_ML_6205V01_0 1B03.BIN]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[M6205_PCB01_GSM_MT6205B_DN.Z6_TTK_N81_ML_6205V01_0 1B 03.BIN]_20080820-121132.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E221A2201:18E59F00000000 Finalization Done pls help me |
08-20-2008, 12:26 | #2 (permalink) |
Member: 573543 Status: Offline Sonork: 100.1602019 Thanks Meter: 97 | hi i solved my problem its cable fault Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:2E4A:CAAD high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: d:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.55433B49.[M6226_06B_PCB01_GPRS_MT6226_S0 1.Z6_TTK_N81_ML_6226V01_01B03.BIN_DA77B1ED].rpl ==================== New firmware detected: M6226_06B_PCB01_GPRS_MT6226_S01.Z6_TTK_N81_ML_6226 V01_01B03.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 55433B49 identification#1 protocol ver: 04 ver. sw1: M6226_06B_PCB01_GPRS_MT6226_S01.Z6_TTK_N81_ML_6226 V01_01B03.BIN ver. sw2: Z6_TTK_N81_ML_6226v01.01b03, 124E8825 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[M6226_06B_PCB01_GPRS_MT6226_S01.Z6_TTK_N81_ML_6226 V01_01B03.BIN]]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[M6226_06B_PCB01_GPRS_MT6226_S01.Z6_TTK_N81_ML_6226 V0 1_01B03.BIN]_20080820-134416.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:2AEA0000000000 Finalization Done file saved: d:\Program Files\InfinityBox\ChineseMiracle\system_log_55433B 49_M6226_06B_PCB01_GPRS_MT6226_S01.Z6_TTK_ N81_ML_6226V01_01B03.BIN_DA77B1ED_20080820-134440.B0X.bin Finished, time used: 211 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-29-2008, 20:41 | #5 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | but not ok for me. i try 2 cable L12B & L14B. same problem. COM7 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 42 sec Remove/Install battery now ! |
09-29-2008, 22:01 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
hello! i dont see reason to work with second MCU. most phone problems can only be solved via First MCU. please find another pinout (for first MCU) and continue work | |
11-30-2008, 21:36 | #7 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 46
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | Quote:
11-30-2008, 22:24 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. |
w810 boot problem or cable problem | noktune_win | Cruiser Suite | 2 | 08-23-2007 01:56 |
GD 87 ERASED BOOT problem | Digitec | Panasonic | 0 | 04-18-2004 22:50 |
LG B1300 bootting problem | Porter | LG | 2 | 12-06-2003 11:59 |
6210 boot problem | Murat Bekar | Nokia Hardware & Hardware Repair | 1 | 03-21-2003 13:18 |
