Old 08-25-2008, 05:49   #1 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
china 6300 problem
COM5 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot disabled
chip: 0001:B503:000F
high speed disabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:E518F000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: E59FF018E59FF018E59FF018E59FF018E59FF018E59FF018
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
detecting firmware version...
can't detect firmware version
if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting languages...
language parameters detected
detected languages: En Ar
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 175 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 08-25-2008, 12:39   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
And What Is Your Problem In Format Time?
The Following User Says Thank You to debmobile For This Useful Post:
Old 08-25-2008, 16:19   #3 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
fone is dead condition...........
Old 08-25-2008, 23:38   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
as long as program failed to read out original software version:
you must try to find flash file by folowing search keywords "6225", "6300"
Old 08-26-2008, 13:15   #5 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Red face phone until dead condition.
i flash fone with this file.
[MTK25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_07 .BIN]]...
here is log.
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 autodetect
Connecting, wait...
CPU: MT6225
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
.damaged firmware
.damaged hardware
ffs chip: 00
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\6300 dead\eeprom_20080826-145401.B0E.bin
Write...
.damaged firmware
.damaged hardware
security area#1 calculation...
done
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 2099 sec
Old 08-26-2008, 15:47   #6 (permalink)
gsm-world's Avatar
Member: 582790
Thanks Meter: 378
download new firmwares from support area of infinity
or backup from working phone
Old 08-27-2008, 07:31   #7 (permalink)
Member: 148515
hello!
how did you pick flash file?
Old 08-28-2008, 12:06   #8 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
need........
sir i read full flash file from a good working fone.
Old 08-28-2008, 14:33   #9 (permalink)
Member: 148515
hello!
looks like your good working phone is different hardware configuration
Old 08-28-2008, 15:02   #10 (permalink)
Member: 767451
Thanks Meter: 178
hello sir pls hlp t108 insert sim card sim a what can i do? to get solution thanxxxxx
Old 08-28-2008, 19:23   #11 (permalink)
Member: 148515
hello mr. fidmdoe!
please more info: after what this happend?
any reason to think that this is software related problem?
China nokia 6300 problem timgsm Chinese Models & Cloned Phones 3 12-11-2009 03:19
China 6300 imei 135 reset problem looupss Chinese Models & Cloned Phones 6 10-21-2009 18:50
china nokia 6300 problem asad_nomy7 Infinity-Box 1 06-05-2008 21:51
new china 6300 problem......help infinity team unlock & flash Infinity-Box 11 05-19-2008 05:10
6300 china flash problem ehsas_ghum Chinese Cocktail 4 12-20-2007 14:20
Page generated in 0.26944 seconds with 9 queries
